Bypass window/wot switch?
Nitrous Outlet window/wot switch wired to tach and tps wires.
jump pin 30 and 87 on the relay?
1) verify that the bottle is closed and there is no nitrous in the feed line
2) remove the fuel line from the nozzle
3) activate the kit
4) using a can to catch the fuel flowing from the fuel line, slowly tighten the screw on the end of the FPSS until the fuel starts to fluctuate.
5) Back the screw off 3/4 of a turn
6) hook everything back up and you are done
Or will it read regardless?
