500HP shot !!!
Old Apr 11, 2007 | 07:07 PM
sonic snake's Avatar
I have sprayed 475-500 and could tell you first hand that with 4 head bolts there isn't anything you could do to keep those heads down next to welding them.We have tried everything and have come close ,but still push some water.
Why do you want to spray 500?Try making some more na power and less of a shot.Unless you enjoy tearing it apart after every pass.
Old Apr 11, 2007 | 07:27 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
With the larger shots you will for sure need alot of top notch internals.Im finishing up my motor and i have L19 headstuds and block and heads have been o ringed so im running copper now.As for how much it will hold with my setup ill be finding out this season.I don't know anybody that has lifted a L19 headstud with o rings and copper gasket.You might wanna call kurt at W2W and talk to him he can set you straight.I know that you will have a **** load of money in the motor to make it right though.Good luck and send us pictures if you dare.
Old Apr 11, 2007 | 09:39 PM
Travis99LS1's Avatar
not to hijack his thread or anything...but lets say you had that LSx block...and you built the motor primarily for N2O, would spraying a 300 shot be reasonable?? I mean i know someone spraying a 250 shot on a 408 LS1....so i would assume that an LSx block with the right internals/tuning should hold a 300 shot with no problem..Am i correct??
Old Apr 11, 2007 | 09:41 PM
brad8266's Avatar
My forged 347 has seen a 300 shot. A properly built LSx block will easily be able to take a 300.
Old Apr 12, 2007 | 09:45 AM
ShiznityZ28's Avatar
Originally Posted by Noyzee
good luck.
those rods are rated at about 600-700 flywheel hp.
we hit my buddies stang with the same rods with 400 plus it made about 400 on motor, and boom sent 1 rod right out the oil pan and bent 4 others
Not so sure about that. or maybe they have different ones. We have rocked Compstars to 900 rwhp on a mustang dyno
Than again i think the pistons will go before the rods.
FYI Im going to hit mine with a 500 this year for sure.
Old Apr 12, 2007 | 10:01 AM
NOS USER's Avatar
I only wanna to know what`s the parts to used to make my engine handle that shot ... Friend of mine with forged rods + dimanod -8.6 pistons ..had shot more then 400hp with no problem in the engine but his gear box broke ....it`s a C5 .
Thanks.
Old Apr 12, 2007 | 10:07 AM
JoeyAnderson's Avatar
Old Apr 12, 2007 | 10:27 AM
bjamick's Avatar
Holly Hell whats the reason behind that much nitrous... WAYYYYY too much money for me but the parts that will be needed will have to be top notch no doubt about that. Even when i build my forged 383 i wont go past 250 unless its a money pass .
Old Apr 12, 2007 | 10:31 AM
next's Avatar
Thanks.
400hp shot with no problems? Sounds like you should just go ask your friend.
Old Apr 12, 2007 | 10:32 AM
95N20FORMULA's Avatar
500 shot???? with all the money ull spend to make it take that and not go boom you could just GO LARGE TURBO..
Old Apr 12, 2007 | 10:56 AM
1ImperialSS's Avatar
formerly silverbrick (changed 02/17/2013)
good luck though.
Old Apr 12, 2007 | 11:37 AM
  #32
B.W.'s Avatar
HAY GUYS WAHT ABOUT A 900 SHOT ANY1 HERE RUNNING TAHT SETUP WAHT WUD I NEED?
Old Apr 12, 2007 | 11:44 AM
  #33
brad8266's Avatar
If you friends motor held up just go ask him how he built his.
Old Apr 12, 2007 | 11:49 AM
  #34
NOS USER's Avatar
Next ...he did broke the gear box .
Im here to learin ..so stop the useless reply for this thread..
Thanks.
Old Apr 12, 2007 | 11:53 AM
  #35
NOS USER's Avatar
But i wanna to know how do the stock pistons handle 200hp shot but with all the forged stuff cant handle the 500hp ???
Old Apr 12, 2007 | 12:02 PM
  #36
Noyzee's Avatar
8 second mod
its not so much the pistions ect. with the rightsetup rods crank pistions, you can hit it with500 worth.
themain issue with thels1 are the heads lifting and pushingwater.
the parts might hold up, butonce you start pushingwater, beware of hydrolock andkiling gasketseveryrunect ect.
Old Apr 12, 2007 | 12:19 PM
  #37
NOS USER's Avatar
Noyzee : If i add a arp heads studs & MLS thick gasket ...It`s will work ?? or just forget about it & put a big turbo ??
Thanks.
Old Apr 12, 2007 | 12:59 PM
  #38
Noyzee's Avatar
8 second mod
Thanks.
its very hard to say. do you have the fuel system to suport it, do you use the correct fuel, ect ect.
im going to have to say unless you have a great tune with all the right parts it will not work, and if it does, it wont be for long.
Old Apr 12, 2007 | 01:33 PM
  #39
next's Avatar
Thanks.
Look at what Sonic is saying as he's sprayed that much. I've gone as much as 450 and these heads don't like it.
Old Apr 12, 2007 | 01:37 PM
  #40
TrickChassis's Avatar
thats a lot of spray!
