500HP shot !!!
Old Apr 12, 2007 | 01:49 PM
  #41
ATVracr's Avatar
Originally Posted by next
Look at what Sonic is saying as he's sprayed that much. I've gone as much as 450 and these heads don't like it.
What heads?
I thought the ESP car was on stock castings.
I think the thicker deck aftermarket castings will help some.
Old Apr 12, 2007 | 03:33 PM
  #42
Noyzee's Avatar
8 second mod
Originally Posted by ATVracr
What heads?
the old silver bulit was on ls1 heads.
the black car had 205 afr heads. it was all listed in the gm high tech performance article the car was in
Old Apr 12, 2007 | 03:42 PM
  #43
next's Avatar
As Noyzee said.
I was/am on AFR 225's (thicker deck) and 1/2" head studs.
Old Apr 12, 2007 | 03:43 PM
  #44
next's Avatar
For what it's worth, I think Ryan (RPM-24) has a great approach - tons of power on motor and a smaller shot. That car is flyin.
Old Apr 12, 2007 | 03:45 PM
  #45
Noyzee's Avatar
8 second mod
thats what im doing this year
Old Apr 12, 2007 | 03:50 PM
  #46
ATVracr's Avatar
Really, tons of power and a shot on top of it and it will fly....Good thinking
He has a BIG MONEY motor set up.
C5R short block , Pimp heads and a sick *** intake.
More money in his motor than I have in the whole car.
Old Apr 12, 2007 | 03:52 PM
  #47
ATVracr's Avatar
Stop it
Old Apr 12, 2007 | 05:11 PM
  #48
next's Avatar
I'm trying to figure out this post. Are you implying that I'm stating the obvious? And is it a bad thing that he has the best money can buy
Old Apr 12, 2007 | 06:10 PM
  #49
ls1408cp's Avatar
so when I do a lsx or dart with 6 head bolts do you think it would take a 450shot? Is their a streetable bottom end setup that would take it? Or would I just be rebuilding it all the time?
Old Apr 12, 2007 | 06:48 PM
  #50
XpEdItIoUs's Avatar
The answer is nothing. You will not keep the heads down with 500hp of nitrous with a 4 bolt head pattern. Just curious, what's the most you've ever sprayed before?
He will also have to worry about keeping the car itself down, So his car won't look like yours but a bit higher.
Old Apr 12, 2007 | 09:07 PM
  #51
Robert56's Avatar
My advice, like most of the big sprayers have said allready, if you have deep pockets go with the LSX block and have a pro builder put it together and tune it. A 500 shot even on a well built motor needs a special spot on tune. Knowledge is key here for survival. I would back down on the shot and learn the game first, or it will cost big $$ to jump head first into the mega shot arena. Even a stock longblock can handle a 250/300 shot if done correctly, but over that, even on a forged motor, your really getting into specialized knowledge area. Good luck on what ever approch you take.
Robert
Old Apr 13, 2007 | 07:12 AM
  #52
NOS USER's Avatar
Thanks guys for your help ...
Old Apr 14, 2007 | 09:18 AM
  #53
ShiznityZ28's Avatar
I never ment my response to sound like it was easy. I have aloty of $$ in keeping this thing togeather. If your thinking standard arp's and MLS your nowhere near where you need to be.
Old Apr 16, 2007 | 01:01 AM
  #54
GueSS Who's Avatar
I was going to try a 600 shot but I made over 800 on one stage of 300. I think I am going to bring the second stage down to 200 to make it a 500 shot. I have iron 412 with Dart (TEA) heads with 1/2 head studs and a cometic gasket. I have 1200 dollar Diamond pistons with billet rods and a lunati crank. I have hellfire rings and big nasty nitrous solid roller with 13.5 compression. We shall see but I would like to make 1K on the chassis dyno
Old Apr 16, 2007 | 01:45 AM
  #55
Ericbigmac83's Avatar
Hey, just wanted to let you know that theres a great article in the May GmHitech performance about a big shot nitrous car. Ya might wanna glance at it if you get a moment. Hes doing a 408 with a 300 shot and is almost in the 8's. So i guess im curious if to whether you realize how huge a 500 shot really is...
Old Apr 16, 2007 | 04:45 PM
  #56
wolfy's Avatar
To the post above ^^^, I'll see your guy with a 500 shot and bet it wasn't an LSx motor. I have a personal friend that sprays 900hp worth of gas, but that ain't no LSx either. I guess that only helps if the question was what can motor can he build that will hold 500.
not to hijack, but this has me curious...did i read that right? 900hp worth of gas? on top of what the motor makes? what is it, whats it in, and whats it make off the bottle?
also, how many lbs is that per run? i bet its alot!!!
Old Apr 16, 2007 | 05:16 PM
  #57
next's Avatar
Yes, on top of what the motor makes. It's a 632ci Sonny's in a 67 Camaro and I think it was around 1200 on motor.
If you want to figure lbs/run... I go through 3.5 lbs on my little shot so you can figure he's a bit more
Old Apr 16, 2007 | 05:40 PM
  #58
JDP's Avatar
JDP
thats next's car
Old Apr 16, 2007 | 05:53 PM
  #59
Originally Posted by JDP
thats next's car
yup, and theres a nice article on it, lol
Old Apr 16, 2007 | 06:16 PM
  #60
ddnspider's Avatar
ive got a random question ive never seen it asked and dunno if anyone even knows.....whats the shot equivalent of just running an open -4 line to the intake?
