Switched 12v power
if your looking for in the car the best is the fuse block imo, but if you have a z28 with no traction control the wiring isstill runto the switch nect to the fog light. i forget which wire it is, but one of them is switched 12v.
also 1 of the 2 ligheres have 12 v switched.
Thanks!!!!
1. Tapped a pink line at the TCS button for the +12V for the arm and heater switches
2. Ran the bottle opener +12v line to the "accy" in the fuse panel. Only negative is this isn't switched - the opener has power at all times.
3. Tapped a pink line under the steering column for the purge +12v
4. Ran my gauges and shift light off the switched source "ign" in the fuse panel.
Most of your pink lines are switched sources. I say most, because I came across one under the dash that was dead, so test them with a meter first (which I didn't do).
