how do you hook up n20 and fuel psi gauges
ive all ways wonderd how you get the gaues on teh a-piller to work with n20 and fuel psi. dumb queston to some maby, but im clueless
it depends on if you use electric gauges or not. the electric fuel pressure gauge has a sensor at the service port that you just screw it in and run the wires to your gauge. as for the nitrous i guess it is the same way but i will probably just run a t and get me a 6 ft line and use a manual gauge.
Same deal with fuel for electronic, but with a manual gauge for fuel pressure you are SUPPOSED to run an isolator, which is full of coolant/water mix, and isolates the fuel from getting inside the cab of the vehicle, which obviously could have its negative side affects in some bad situations. An isolator from Autometer runs about 70-100$ last I looked(and purchased).. I have yet to use mine though, considering an electric for simplicity's sake.
-Lurius
-Lurius
