Daves Plate jetting?
I have 52 33 and 62 38 already
what else should I get:
32 34 36 37 58 59?
Is a 125 about 58 35?
HP N20 Fuel
50 – 35 22
75 – 41 28
100 – 52 33
*125 – 57 33
150 – 62 38
*175 – 73 38
200 – 78 46
* - This jetting is just a rough starting point
Final Jetting will need to be determined by Customer
A/F Ratio will also need to be checked
Question, how much does owering the fuel jet from 38>35 affect the AF in fuel?
I say 35 because that jet is available in the kit.
Why did you swap?
You could also go with a 70 nitrous jet and see where your at.
Is that about 12.2 at the leanest point?
12.2 looks about right, we tested jetting on the dry and then Daves plate we combined a dry shot with the wet for a final two stage combo.
Since then I have added 42 # injectors, Headers, and a Racetronics fuel system, as well as EFI Live for tuning. We are going to revisit the dyno in May.
Looking at Colonel N20 files I find that they use 63/36 for same rating. I think I'll give the 62/35 a try with a bit more fuel via tuning to see where I'm at. adjust via power enrichment as needed.
Man I need to get one of these multi jet kit .
I allways carry a numbered drill bit set with me when going to the dyno. this way you can drill any smaller jet out to the exact size you want, makes the job of dialing in a system much easier. just rememebr to allways re-mark a drilled jet.
Robert
