What nos jets for single nozzle 200 shot just checking
Im about to order some n2o jets im planning on running a 200 shot on a NOS single nozzle. I have read the lists in the nitrous jet sticky and searched im just trying to make sure here. The colonels jet sizing for a 200 shot is a .82 and a .44 and dynotunes calculator says .67 and a .40 which the numbers are pretty off. So im wondering what kind of jets you guys are running for a 200 shot with the nos style flare jets not the nx kind. I have been using the colonels n2o tables for awhile without any problems. But I noticed that there is pretty big difference in the jetting.
LS1TECH Sponsor
Dean
I got flywheel horsepower with the colonels jetting I sprayed 125 shot and got about 90 rw. I wouldnt see why the nozzle wouldnt flow 200hp. I have heard of people spraying 200 on single nozzles with out a problem I think once you get around 250 you should use two though correct me if im wrong?
The NOS nozzle will not flow 200hp. The Soft Plume (Stainless) is limited to about 150 and the "B" nozzle to less than that. The only NOS nozzle that would is the "A" nozzle it is the highest flowing nozzle NOS currently makes.
