schrader valve problem
Old Apr 22, 2007 | 08:30 PM
Camaro94SS's Avatar
Default schrader valve problem
So i have everything installed now, and im trying to test my noids with the FPSS on and the car running...my wiring is all correct because the noids click when i bypass the FPSS....i had the fuel line in a bottle to see if fuel would come out when the FPSS was bypassed and no fuel came out but the noids were clicking....im not exactly sure how to remove the valve i guess.....there was a twist **** on the the schrader valve so i jsut took it off and screw the an fitting on.....i never used a valve stem remover, i guess im just asking if I forsure have to use a valve stem remover even though the schrader valve was covered by a twist cap and the line screweed on just perfect...???
Old Apr 22, 2007 | 08:36 PM
Beer99C5's Avatar
Get a tire valve stem removal tool (Walmart or any auto parts store $3), insert it in the hole and unthread the valve.
It is just like what is on a car tire or bicycle tire. Practice on a bike tire first if you like.
Be sure there is no fuel pressure and the car is cold when you remove it, put a couple paper towels under it to catch any fuel that drains out when you pull the valve out.
Old Apr 22, 2007 | 08:37 PM
Camaro94SS's Avatar
so i for sure need to get a valve stem remove and do that...?
Old Apr 22, 2007 | 08:40 PM
01'WS6's Avatar
I do it with a tiny screw driver but i would highly recomend a shrader valve remover tool. And YES it has to be out for the kit to work.
Old Apr 22, 2007 | 08:41 PM
Beer99C5's Avatar
The right tool for the right job.
You can try what ever you like, its your car.
Old Apr 22, 2007 | 09:05 PM
nickdotcom's Avatar
or go to a tire store and ask if you can have/barrow one, if its the same thing, and im pretty sure it is, then i have 3 in my car right now on accident
Old Apr 22, 2007 | 11:12 PM
caliswangin916's Avatar
autozone has a cheap 4 way tool for $3-4 that will work fine. then you can put the stem back in later if you want. i would not want to **** up that fuel rail.
Old Apr 22, 2007 | 11:16 PM
Camaro94SS's Avatar
i tried a normal bike stem valve remover and it was too small....so is there different size removers?
but im high =) LoL
Old Apr 22, 2007 | 11:31 PM
Camaro94SS's Avatar
Old Apr 23, 2007 | 12:03 AM
nofearracing28's Avatar
Yes, there are different size removers
