Want to cover my bases on this set up.. Dart heads F14 cam and 175 shot.
I have a TB plate kit with a NX wet kit jetted for 175 shot. I just installed a set of Dart 205 heads and a F-14 cam. I also have a window switch set at 3000-6700 RPM's The engine is a fresh rebuild, but with stock parts all except the rod bolts (ARP) better rings, bearings etc. The car is converted to an A4 with a Yank SS4000 stall, and a stage 5 RPM transmission, and a 9" rearend. I also have a Racetronix fuel pump, and 30# SVO injectors, and a LS6 intake. I want to know what the recommended setting should be as far as my timing, and... well.. will it be safe to run a 175 on this engine and having a TB plate as the means of distributing the nitrous?
Thanks for any input.
