Traction control?
Old Apr 24, 2007 | 10:15 AM
SY732's Avatar
Default Traction control?
2006 C6 WOT via TPS
Can I spay in TC off mode?
Can I spray in COMP mode?
Old Apr 24, 2007 | 11:39 AM
Todd157k's Avatar
You don't want TC on while spraying. The PCM is cutting power while you're trying to feed in more power. Comp mode is probably fine though.
Old Apr 24, 2007 | 03:40 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
I'm not sure about an 06, but on my 01 I do believe that even with TC off the DBW was closing the throttle blade at pedal WOT. I'm not sure how that would work while on the spray, hopefully it would richen up along with the timing cut eneough to keep you ok. And your window switch would cut it off if comp mode got your rpm too low. I don't recall what the tables were to force blade WOT when the pedal is WOT, but I did narrow it down to only a few tables.
Old Apr 24, 2007 | 03:48 PM
transamfreak01's Avatar
yeah take the TC off when u give it spray it wont let u push all the power through
