Which TPS wire on a C5 for WOT switch?
I do know that...
Dark Green/White = TPS 1 signal reference
Purple = TPS 1 ground
Dark Blue = TPS 1 signal
Yellow/Black = TPS 2 signal reference
White = TPS 2 ground
Pink = TPS 2 signal
...I'm assuming that I would use the TPS 1 set but not sure of the difference between "signal" and "signal reference". I know the WOT switch (Zex) looks at voltage.
04 GTO LS1 TPS at the throttle body BLUE wire. at the computer pin 24 grean seal connector 2. blue wire
TACH coil trigger wire light green passenger side, at the computer pin 10 green seal connector 2. brown wire
05 GTO LS2 tps at the computer pin 31 green for falling black connector. tps at the throttle body Green wire
tach coil trigger wire light green passenger side., at the computer pin 48 blue connector 1 Brown wire I believe..
Someone might want to check me on this.
Ricky"
