Building A 408 What Cam?
Old May 4, 2007 | 04:23 PM
dnkynrbk's Avatar
Default Building A 408 What Cam?
Just getting ready to build a 408. Im going to use my same heads 11-1 comp. and just wanted to know what cam would work the best with F2 KIT spraying a 250 shot or more. I didnt know if there was a good cam out there or if you guys would recomend a custom grind cam and what size. Set up with be a t400 with 373 gears. thanks
Old May 13, 2007 | 09:01 PM
dnkynrbk's Avatar
anyone on this? or does anyone have a set up like this.
Old May 13, 2007 | 09:10 PM
JDP's Avatar
JDP
everybody usually says to go with a custom cam, i heard eastside performance can hook you up with a good nitrous grind
Old May 13, 2007 | 09:19 PM
beardWS6's Avatar
I went with a 250 255 640 640 112 lobe with my 408. Car makes good N/A power and sprayed we`ll! Good Luck!
Old May 14, 2007 | 07:42 AM
Noyzee's Avatar
8 second mod
east side can hook you up.
id say for a streetable cam 24x 610 ish on a 112
Old May 15, 2007 | 10:21 PM
nwi goat's Avatar
custom nitrous grind from lme here...
Old May 15, 2007 | 10:53 PM
dnkynrbk's Avatar
Just looking for a awsome thumping cam but you that you can keep a tune and not adjust when you go to the track everytime. Looking to spray a 300 shot
Old May 16, 2007 | 09:58 PM
Robert56's Avatar
Just get a nice aggressive cam your happy with for n/a needs. unless your NHRA bound or a dedicated bracket car, a dedicated nitrous cam is not needed. I am thinking about the MS 4 cam for my 408, and I'll be spraying 300 also. A nitrous cam will allow the nitorus to be more effective, but at the hinderence of n/a power.
Robert
Old May 17, 2007 | 12:39 PM
beardWS6's Avatar
Robert
I agree! Get the baddest cam you want and just spray it! You will be all right! I did!!
Old May 18, 2007 | 03:04 PM
LightFighter's Avatar
Robert
I'm thinking about going with the MS-3 with 113 LSA I see the MS-4 only comes in 111-112, or is it not that big of a deal?
Old May 18, 2007 | 05:31 PM
JDP's Avatar
JDP
im going to have patrick g spec out my cam for my motor, just let him know what you have and what you want out of it and hell get you what you need.
Old May 18, 2007 | 11:48 PM
Robert56's Avatar
yea, a 113 would be better for the nitrous side for sure, imo, but for a good n/a 500rwhp the ms4 might be better. So trade offs for sure. How much better 113 would be, not sure, but I believe it would help the exhaust side out for nitrous. Maybe some of the cam geeks will see this and have some additional insight. (cam geek-a good thing)
Robert
Old May 20, 2007 | 06:04 PM
1MEANGTO's Avatar
My cam is a 236/242 608/612 on a 115. Its all about what you want to run for the most part. I went for a more spray freindly cam as you can see with the 115 you can get a ms3 or ms4 on whatever lsa you want from comp cams. They use standard comp catalog lobes on tsp's cams.
Old May 20, 2007 | 07:29 PM
BadAssFast's Avatar
I used a FM13 114 for my LS1 and continued using it in my 408 - mid tens all day long and easy on the street. I want a bit more chop and a better match for my motor so Allan cut me a custom cam 6 months ago that matched my system. My car will be down for a month to prepare for the summer racing, but i'll report back on my Futral Motorsports Custome grind pushing a progressive 400 shot through my Nitrous Outlet plate on a 408. (Bring on Pinks All Out @ Bristol !!)
Old May 20, 2007 | 10:38 PM
LASTLS1's Avatar
6 Second Club Moderator
I have a FMS nitrous cam for you I used in my 408, it thumps! Solid roller.
Old May 21, 2007 | 02:46 PM
Lurius's Avatar
Havent really even driven the truck with new motor.. But heres a 408 iron block, 10:1 CR, with an ms3 and open cutout, incase you wanted to see what an ms3 sounds like in a 408 since some guys here suggested it. Its a 113LSA as well.
http://video.google.com/videoplay?do...93375227317134
-Lurius
Old May 21, 2007 | 06:31 PM
Robert56's Avatar
-Lurius
Man that sounds sweet, nice job.
Robert
Old May 21, 2007 | 07:09 PM
JL ws-6's Avatar
Race your car!
Call estside and ask about the cam that they put in my 402.... n/a power $'s in my sig and that's thru a 5000 converter and a th400..... and it's a nitrous cam
Old May 22, 2007 | 09:16 PM
BadAssFast's Avatar
There is a trend here !!
Old May 22, 2007 | 09:32 PM
Robert56's Avatar
That 408's are Bad *****?
Robert
