What bellow with Dave's Plate?
Old May 11, 2007 | 10:51 AM
SiL3NtXWS6's Avatar
Default What bellow with Dave's Plate?
I have tried a stock one and then i tried another stock one that was trimmed and i can't get my lid back on because the bellow is too scrunched.
Cannot find a silicone hose to fit at any hardware store ( 3.5 X 3 )... so i'm not quite sure what to do at this point.
I have a 90mm TB , stock MAF.
Old May 11, 2007 | 10:58 AM
SmaknaSS's Avatar
I just cut down the stocker on both ends. It seems to be fittin OK.
Old May 11, 2007 | 11:36 AM
Noyzee's Avatar
8 second mod
i just did one with an slp. cut about 1/4" off both sides and cut the little notch around the t-body thing, and good to go
Old May 11, 2007 | 11:51 AM
NHRATA01's Avatar
I just used a silicon hose from Intakehoses.com.
90mm TB and 85mm MAF, I think I used like a 3.75" to 4" coupler. Don't remember the length, measured it up and ordered a close size, then trimmed a hair off as needed.
Old May 11, 2007 | 11:59 AM
SiL3NtXWS6's Avatar
4 inch ID or OD
Old May 16, 2007 | 10:36 AM
SiL3NtXWS6's Avatar
if anyone is curious, i was able to cut a some off my stock bellow to make it fit. I cut up to the first rib on the MAF side, then secured it with the stock clamp in between ridges. Works fine and looks factory.
By the way... plate hits much better than a single nozzle.
