Does Wet System Need retune?
Old May 14, 2007 | 09:40 AM
bluecamaroz28's Avatar
Default Does Wet System Need retune?
Engine is tuned NA for H/C. Does it need a retune, for A/F ratio with wet system or is timing retard and colder spark plugs enough?
Dedicated fuel pump will be used for the wet system, 200-250HP single nozzle system.
Old May 15, 2007 | 09:20 PM
5_02ls1's Avatar
WAIT4ME done my n/a tune and he said as long as i hadv myb fuel jetting correct the tune would be fine
Old May 15, 2007 | 09:26 PM
CuNfUzEd's Avatar
I had mine retuned for A/F. It all matters man. Do a dyno with A/F, you need to be around 11.1 on the squeeze.
Old May 15, 2007 | 09:27 PM
Ryan_Z28's Avatar
I would say absolutely yes. if you running a tuned h/c setup theres no timing pulled in consideration for the size shot you want to run. you will need colder plugs and timing pulled
Old May 15, 2007 | 10:29 PM
5_02ls1's Avatar
i didnt see the h/c before i posted yeah you need a retune for that big shot
