408 ShortBlock is here, pics
Old May 28, 2007 | 08:57 PM
  #41
BadAssFast's Avatar
Robert my shop has had several motors built by LME. Bryan knows my biz partner Dave Moore real well. We have a Cobra that just dyno'd out just short of 750 rwhp...my LME 408 car last dyno tune was 636 rwhp with a 200 shot. That was to keep it able to run on the street. I can't say how many more LME motors we have...3 or 4 both Ford and Chevy? You'll have some real fun now.
Old May 29, 2007 | 02:25 AM
  #42
myfast70's Avatar
Robert,
Nice motor!! How come you wouldn't use a coated piston with the use of nitrous?
Old May 29, 2007 | 07:50 AM
  #43
Noyzee's Avatar
8 second mod
robert, 2 things. one is spend the $$ on felpro gaskets and hit them with copper spray. the gm dont work as well. the felpro have a special coating on them and they work MINT, you will find out when you try to tq gm gaskets to 90 lbs i dont think it will work out to good.
also, does the l92 head have a thicker deck?
be carefull clamping the stock heads to 90ftlb
id probably stay around 80 lb with ls6 heads.
good luck
Old May 29, 2007 | 03:56 PM
  #44
LostCauseZ06's Avatar
good luck
maybe im missing something buy my fel pros sucked ***. and ive heard nothing good about them from anybody besides thunder racing.
i run the GM 6.0L MLS Gaskets and they work sweet for me.
Old May 29, 2007 | 06:39 PM
  #45
Robert56's Avatar
Yea, that's what I have been hearing from the engine builder and from some respected engineers, run the 6.0 MLS.
As for torque on the heads, LME said to torque to 90 and they know I am running the LS6 heads to start out? Do the progressive torque up to 90, then go back one by one and loosen then retorque to 90.
On the coated pistons, well at my level, I don't think I really needed coated and gas port pistons. When I build my LSX and go real big, then yes, up another notch.
Robert
Old May 30, 2007 | 07:37 AM
  #46
Noyzee's Avatar
8 second mod
which fel pros?
there new mls gasket or the old style with the wire?
i ran the felpro mls and had great luck. i ran them in my car and a couple other cars. also we run them on my buddies 8 second nitrous mustang, and another buddies 8 second 15-1 all motor car with great success.
i run the gm mls on my heads/cam cars, but thats about it
Old May 30, 2007 | 07:46 AM
  #47
Noyzee's Avatar
8 second mod
some good info in this post about fel pro. some big dawgs runnin them as well.
https://ls1tech.com/forums/showthrea...58#post7151658
Old May 30, 2007 | 10:32 AM
  #48
which fel pros?
fel pro makes MLS gaskets???
thunder sold me 4.125 bore fel pro paper gaskets, they were blue and gray. they blew out in no time at all and i then ordered the new GM MLS gaskets that are basicly 3 sheets of thin steel on top of each other with some black rubber to seal around the water jackets and stuff.
Old May 30, 2007 | 12:17 PM
  #49
Noyzee's Avatar
8 second mod
the ones you got are basic fel pro aka junk for anything but stock cars.
these are the good ones and i have had great luck
Felpro Gaskets
Felpro Gaskets
Part #'s are just for a single gasket!
itemno description price buy
FEL9284PT Felpro LS1 Head Gasket $23.99 ea buy
FELES72173 Felpro LS1 Head Bolt Package $24.99 ea buy
FEL1041 LS1 Head Gasket Bore 4.135, Compressed Thickness .041 $66.99 ea buy
FEL1160L LS1 Head Gasket (MLS) 3.945 Bore, Compressed Thickness .053 - LEFT $89.99 buy
FEL1160R LS1 Head Gasket (MLS) 3.945 Bore, Compressed Thickness .053 - RIGHT $89.99 buy
FEL1161L LS1 Head Gasket (MLS) 4.100 Bore, Compressed Thickness .053 - LEFT $89.99 buy
FEL1161R LS1 Head Gasket (MLS) 4.100 Bore, Compressed Thickness .053 - RIGHT $89.99 buy
FEL1162L LS1 Head Gasket (MLS) 4.175 Bore, Compressed Thickness .053 - LEFT $89.99 buy
FEL1162R LS1 Head Gasket (MLS) 4.175 Bore, Compressed Thickness .053 - RIGHT $89.99 buy
Old May 30, 2007 | 02:19 PM
  #50
ELMiN8oR's Avatar
good luck with the set up
Keep em coming.
Old Jun 3, 2007 | 01:31 PM
  #51
Robert56's Avatar
Update pic (actually farther along than this), gawd it's beautifull. Most everything is here. just waiting on a custom spec'ed cam, details on cam later. really starting to get excited. Hope I can get this tub of bolts into the nines?
Robert
Old Jun 3, 2007 | 10:31 PM
  #52
BadAssFast's Avatar
Robert
if you don't squeeze a 9 - you should be on the low side of 10s. What are your cam specs? 245/255 ish with 640/620 range with a 113 lobe for the n20? FMS cut mine somewhere in there...with my old FM13-114 mid tens were easy. I have not run the new cam since it's part of a huge lightening/balance/safety project we are doing along with a new n20 - multistage...I expect to see high 9s after a few dial in trips...we'll see. Anyway - that's a loose motor - you'll see some puffs and watch your oil consumption on a built for n20 motor closer that the old stocker. What I had a bit of a problem was getting my oil pan to stop leaking in the corners. My biz partner said that had more to do with that gasket staying lined up...apparently that takes a tool?? I don't know. And what rear gear you using??
Old Jun 3, 2007 | 10:52 PM
  #53
BadAssFast's Avatar
FAST 90 Intake Manifold - just screw in 8 dry nozzles into the manifold? Run eight lines from a 8 way junction to a noid? What nozzle would be a best choice?
Old Jun 4, 2007 | 05:39 PM
  #54
mrr23's Avatar
don't forget to check the windage tray for clearance of the rods. at 1/8" washers, i thought i had enough. checked while on engine stand and had clearance. rod bolts just barely touched while the engine was running. having to notch the tray where they hit.
Old Jun 5, 2007 | 12:39 PM
  #55
Robert56's Avatar
Yea running a DP I am not sure I really need to go that route. Haven't found a limit to the front entrance MAF style yet. Also, no distribution problems so far that i Know of going dry to at least 300rwhp shot, not limited on size like wet for going to DP.
Robert
