ring gap question!!!!!!!!!!!!!!!
Old May 26, 2007 | 03:17 PM
fstls2camaro's Avatar
Default ring gap question!!!!!!!!!!!!!!!
do you know what the ring gaps are supposed to be for a ls2 4 inch bore it is stock pistons and rings but i also want to spray a 150 shot any help is appreciated
Old May 28, 2007 | 02:25 PM
anyone
Old May 28, 2007 | 02:32 PM
1MEANGTO's Avatar
Mine are gapped at 6 thousanths per inch of bore.
Old May 28, 2007 | 04:16 PM
Robert56's Avatar
Mine are .028 top, and .021 2nd, however, my shot will be around 300.
Robert
Old May 28, 2007 | 05:03 PM
Black X's Avatar
Recommended by Diamond for my application. 4" bore with plans of 200 shot.
0.024" Top
0.026" 2nd
Old May 28, 2007 | 05:09 PM
Juiced C5's Avatar
Robert
How do the ring gaps work??? the higher the # the looser the gap, or vice versa???
Old May 28, 2007 | 05:18 PM
Black X's Avatar
Thats correct think about it like a spark plug gap.
Old May 28, 2007 | 05:27 PM
Juiced C5's Avatar
cool, thanks... so what does the top and 2nd ring gaps do... in regards to nitrous??
Old May 28, 2007 | 06:18 PM
Black X's Avatar
You need to make them a little larger so as the huge amounts of heat are applied to them while under nitrous load they ring ends do not come in contact with eachother. Also known as "butting" the rings and a major cause of broken ringlands. One of the comon failures associated with Nitrous usage
Old May 28, 2007 | 06:22 PM
Juiced C5's Avatar
So how do u know if youre gap is to loose or to tight for a given nitrous hit??
lets say....
top-.028
2nd-.025
as apposed to robert56's
top-.028
2nd-.021
given each's ring gaps, what size nitrous hit would u use on those ring gaps??
Old May 29, 2007 | 02:19 AM
what is the stock ring gap for a ls2
Old May 29, 2007 | 07:52 AM
Tony Shepherd's Avatar
For nitrous engines you want the 2nd ring gap larger than the top such as 24 top and 26 bottom....etc.
Old May 29, 2007 | 08:38 AM
1936FordPU's Avatar
Thats how I always understood it. On a 3.9 bore ive always used .024 and .028 for nitrous motors.
Old May 29, 2007 | 09:18 AM
It also depends on what size shot they plan on running. The larger the shot...the more you want to gap them.
Old May 29, 2007 | 02:07 PM
does anyone know the stock ls2
ring gap
Old May 29, 2007 | 03:14 PM
1MEANGTO's Avatar
ring gap
tight
Old May 29, 2007 | 03:50 PM
1MEANGTO's Avatar
Originally Posted by 1MEANGTO
tight
I'd go out and measure but I'm way tooooo lazzyyy today and if I see my car I'll have to work on it.
