Anyone spraying on stock GM plugs?
Old Apr 30, 2003 | 10:26 AM
AZ28driver's Avatar
Default Anyone spraying on stock GM plugs?
Is anyone spraying on stock GM plugs? If so how big a shot are you using and what type of results did you see doing it?
Old Apr 30, 2003 | 03:37 PM
CAT3's Avatar
Restricted User
Default Re: Anyone spraying on stock GM plugs?
I have sprayed on them before, not recommended. Change them out to at least TR6's for safety. I used to spray a 100wet shot, but after realizing what a POS those plugs are I switched. Gapped the TR6 top 38 and it was spray heaven!
Old Apr 30, 2003 | 03:55 PM
xaon's Avatar
stock GM plugs are platinum, you will melt the tips right off the plugs. I use NGK TR6's in my car.
Old Apr 30, 2003 | 07:36 PM
AZ28driver's Avatar
Thanks for the info.
