nitrous pull....
Old Jun 4, 2007 | 03:24 PM
gtobizman's Avatar
1 hp gain from 100 to 150 looks like fuel starvation. Your MAF can only compensate so much.
Old Jun 4, 2007 | 04:07 PM
edcmat-l1's Avatar
Originally Posted by LastLT1
i am spraying before my MAF, i have the nozzles on both sides of the air lid pointing towards the maf.
OK. just looked at the directions and thats where it should be. Learn somethin new everyday. Never put one in that sprayed across the maf.
Old Jun 4, 2007 | 05:39 PM
NVR KNO's Avatar
where is the best place for the nozzles?
Old Jun 4, 2007 | 05:41 PM
NVR KNO's Avatar
what is the best place for the nozzles?
Old Jun 5, 2007 | 07:11 AM
NVR KNO's Avatar
is there a better place to position the nozzles?
Old Jun 5, 2007 | 07:16 AM
newtoLS1s's Avatar
try taking nitrous pressure to 1000PSI and check the A/Fs
Old Jun 5, 2007 | 08:45 AM
NVR KNO's Avatar
fuel should be fine.... just put 42lb injectors in and i have a FPSS so if the pump couldnt handle it, wouldnt the switch shut it off? there was no missing in the upper rpms either.
Old Jun 5, 2007 | 09:16 AM
BADSZ28's Avatar
Originally Posted by edcmat-l1
HUH???? you sprayin ahead of your MAF? Whenever you add or subtract nitrous, whether its with a jet change or increasing/decreasing pressure, it will lean or richen the mix.
I do agree with the colder plug for N2O, but the way it was referenced earlier just didnt make sense. Alot of people dont understand spark plug heat range.
Yes, in a wet system you are correct, but with a dry shot across the MAF, the MAF will read more air (cooler temps) and add fuel when adding nitrous and visa versa. Also, if the jets are pointed directly at the MAF wires it will read more rich. I have never heard anyone run dry after the MAF. Well except PatrickG, but he has a special SD tune that adds fuel and the bowling ***** to do it.
Fuel system limitations were never a concern based on the data LastLT1 gave. So I still think it is timing and plugs. The bigger the shot, the less timing you want and the colder the plug you need to run. If the car is tuned for NA, most likely needs to have some timing pulled.
Old Jun 5, 2007 | 09:19 AM
BADSZ28's Avatar
For now, stay off the button till you get plugs. My tuner would not touch my car till I changed my plugs had at least 42s and upgraded the pump. You are SI so pump should be fine. All else is fine sounds like.
Keep the nozzles in the kit specified location. Seams to work well there.
Old Jun 5, 2007 | 09:30 AM
Noyzee's Avatar
8 second mod
well, here is my input.
put tr-6 in there right away.
run 1100-1200 psi on the pressure (that ket needs pressure)
be very carefull with af on the dyno, you want it around 11.5- 12.1 on the dyno, that on a real pass will be close to perfect.
the jetting is not correct either, the 34 jet i believe is 125 at the motor so a 40 would be about40 more crank HP
timming will also effect HP.
pressure from 900 to 1100 will pick up about 25 hp if the tune is correct.
good luck
Old Jun 5, 2007 | 09:56 AM
NVR KNO's Avatar
thanx guys. ill be at the shop on thursday so ill let you know then how it pans out.
Old Jun 5, 2007 | 02:25 PM
  #32
edcmat-l1's Avatar
Definitely.....
Old Jun 5, 2007 | 02:28 PM
  #33
edcmat-l1's Avatar
Yeah I agree. Its probably a timing issue. I would pull 3 degrees out right off the bat. Not across the board but where the nitrous is activated. And I agree on the plugs also, although that has nothing to do with the amount of power it makes.
PS Get the bottle pressure up too. Pressure = power.....
Old Jun 5, 2007 | 02:32 PM
  #34
edcmat-l1's Avatar
Did anybody else have any problems with the site late yesterday? I posted a few times but when I looked they were never there. Very strange. Dang computer gadget thingys
Old Jun 5, 2007 | 02:48 PM
  #35
NVR KNO's Avatar
good luck
yea but isnt the limit on the 15lb bottle only like 1300psi?
Old Jun 5, 2007 | 02:49 PM
  #36
NVR KNO's Avatar
the database was messed up yesterday. i pmd Noyzee and that what he told me. that why you and me have 5 posts saying the same thing.
Old Jun 5, 2007 | 03:17 PM
  #37
BADSZ28's Avatar
Plugs have to do with being safe, not power when talking power adder.
The kit is rated at 950psi. No sense in going higher unless you want to avoid pill changes. I do it so I can not frown upon it, but I know what I am pilled for when I do it. If you put in more pill and raise the psi, you are going to have a much larger hit. Also, I have found that as the bottle gets lower, higher pressures take longer to reach if at all. So just go with the right pills. With 4lbs left in the bottle, it took FOREVER to reach 900psi. Under rated pressure.
Old Jun 5, 2007 | 04:47 PM
  #38
edcmat-l1's Avatar
Well aware of that.
Old Jun 5, 2007 | 04:49 PM
  #39
Noyzee's Avatar
8 second mod
i run my dry kit on my vett at 1150 shut off on the bottle heater pressure switch. i had an issue with the noid sticking once, but i ditched it and got a new one and since then its fine.
Old Jun 8, 2007 | 01:37 PM
  #40
NVR KNO's Avatar
well i picked it up yesterday. changed the plugs to the tr6s and she runs tip top! had alil issue with the window switch interferring with the spark made by the plugs, but seemed to have fixed it. took her down the road for the first nitrous run and she definetly has some more *** to her now!! she pulls hard as **** in 4th gear too!!
