a/f ratio question.....
Old Jun 5, 2007 | 08:30 PM
b4ckid02's Avatar
Default a/f ratio question.....
i got my car up on the dyno last night. Before the 100 shot dry the car made 322rwhp. with the 100 shot it made 355rwhp. the a/f ratio was almost 16:1 at one time. i no thats not good at all and it should be around 10:1 or 11:1. I tried a search and i couldnt find anything but i was wonderiing if where i have my nozzle located can effect the air to fuel ratio. If it does i want to know wheres a good spot to put it. I have a 02 camaro w/ the slp lid. Pictures would be highly appreciated. thank you
Old Jun 5, 2007 | 09:19 PM
BriancWS6's Avatar
Yes, it most definately will. If its too far from the MAF, you will get a lean spike at the start of the hit, and the sustained a/f will also be leaner. The best place to put your nozzle is in the neck of the lid, about 3-4 inches away, pointing directly toward the MAF, using some 90* nozzles.
Old Jun 5, 2007 | 09:48 PM
BIRDONNOS's Avatar
heres a pic of my dual stage, the single nozzle in the neck closest to the maf has the best results as a/f for me, anywhere from 11.0-11.8 depending on bottle pressure and what shot i spray at the time, if it goes to fat i just jet the front kit up to bring the a/f in line to where i want it to be.
Old Jun 5, 2007 | 09:51 PM
Derek @ EDO's Avatar
WHOA 16:1! where is your nozzle located currently?
Old Jun 6, 2007 | 08:24 AM
b4ckid02's Avatar
I have my nozzle located on the side of the lid...I have my single nozzle were BIRDONOS has his secound stage nozzles pointing except I only have one....
Old Jun 6, 2007 | 06:26 PM
bad6as's Avatar
is it a stright shooter? or does it spray at an angle. eather way a 90* in the neck would be better, but dual nozzles in the neck would be even better
Old Jun 7, 2007 | 11:19 AM
b4ckid02's Avatar
It is a straight shooter....iam going to get a 90 and put it in the neck....thank you for all your help
