Purge through the Firehawk heat extractors??
Old Jun 7, 2007 | 11:09 PM
bluehawk2's Avatar
Default Purge through the Firehawk heat extractors??
Has anyone ever ran their purge throught the heat extractors on a Firehawk hood?? It would look really cool, but I don't know excactly how I would pull that off.
thanks,
Brent
Old Jun 8, 2007 | 02:07 AM
Lythropus's Avatar
Mine is going to have a 70inch 3an line run from my purge up to the center of my hood down to the front where it splits off into dual 3/16th aluminum lines and then enter the nostril area into twin NOS LED purge lights, I planned on using self tapping aluminum screw and adele (sp?) clips to attach it to the hood since there is a small gap from the upper part of the hood in the center. If that doesn't work I'll use some adhesive zip-tie thingies....
I used the Nitrous Outlet dual purge and had to drill out the NOS LED lights to make them fit...I'll also have to cut out a little section of the nostril area from the underside of the hood to fit in the purge light LED's.
