PLX wideband install
Old Jun 9, 2007 | 09:11 PM
97rs4life's Avatar
does the gauge get the power from the box then? There is a female plug on the gauge that is wrapped up, what does that go to or do I leave it wrapped up?
Old Jun 9, 2007 | 09:27 PM
fastlt1's Avatar
Power is from the box. Leave it wrapped up it is for multiple PLX guages.
Old Jun 9, 2007 | 09:32 PM
97rs4life's Avatar
alright, thanks for all the help getting this all figured out now, one last question, what is the grey wire for that is part of the red and black wires, anything? Oh yea and those noise eliminator things, anything done with those?
Old Jun 9, 2007 | 09:46 PM
WPBTA's Avatar
i want to know the same thing everything else helps very much so far.
Old Jun 10, 2007 | 08:15 AM
MUSTANGBRKR02's Avatar
very helpful thanks fastlt1
Old Jun 10, 2007 | 09:49 AM
fastlt1's Avatar
I used the black and red wire to run power to the unit. Grey wire still in box.
Old Jun 10, 2007 | 12:24 PM
WPBTA's Avatar
so u dont have to use the gray wire
Old Jun 10, 2007 | 04:08 PM
BriancWS6's Avatar
I havent had luck getting mine completed either. I read the instructions, but it said not to use the wire thats not attached to the white plug if you were using it for gasoline. So, I taped the end of it and left it. The only thing I have in the white plug is the one it came with.
Then I wired the black/red wires to a ground and power source in the car, and plugged it in to the far left. I turned the key forward and nothing came on. The only thing I have differently than the pics above that I know of, is one less wire in the white plug.
Can someone help me get squared away?
Old Jun 10, 2007 | 04:37 PM
97rs4life's Avatar
there is going to be a slight delay before you get a reading on your gauge as the wideband warms up and all. Thought I read somewhere it was like 45 seconds or something. Maybe give it some more time to activate
Old Jun 10, 2007 | 05:06 PM
BriancWS6's Avatar
Yeah, I read that, but, there's nothing coming up on the gauge at all.
Old Jun 10, 2007 | 06:00 PM
WPBTA's Avatar
i got mine all in but when i put the 2 wires in the analog spot it don't work it shows .99 and dosent move.When i take the 2nd wire out it works.Will it be find with just one wire it.
Old Jun 10, 2007 | 06:22 PM
  #32
97rs4life's Avatar
yea the way I understood it was that you need only one wire, the other is for lambda or whatever
Old Jun 10, 2007 | 09:44 PM
  #33
WPBTA's Avatar
got everything in works fine it reads at idle 13.9 to 14.1 is that normal
Old Jun 11, 2007 | 05:37 AM
  #34
fastlt1's Avatar
You have to use both wires for WB use. I think it said you did not have to ground. Make sure it is in the diagonal.
This is looking from the back of the plug.
Old Jun 11, 2007 | 01:14 PM
  #35
Danger731's Avatar
Just got mine delivered today ! will be back looking at this thread in a few weeks for my install !, MORE PICS PEEPS !!
Old Jun 11, 2007 | 06:43 PM
  #36
BriancWS6's Avatar
Ok, so the reason mine isn't working is because it blew a fuse in the car when I turned the key on. And.... the reason it blew a fuse, is because somehow a bad batch of power cords got out, and, lucky me, I have one
I called PLX and the technical support guy was very nice and helpful. He is shipping me out a new one asap, and apoligized for the inconvienance. I'll let you guys know how it all turns out once the new power cord get's here.
Old Jun 11, 2007 | 07:48 PM
  #37
mrr23's Avatar
no you don't. as the instructions say, the other wire is for lambda readings. i am not using the second wire, or the gray wire on mine. the instructions are kind of difficult to follow. so, i called and had it up and going in two minutes.
Old Jun 11, 2007 | 09:57 PM
  #38
Johnny5's Avatar
who's got the instructions/pics to install the WB in a NB bung and keep everything working?
Old Jun 12, 2007 | 10:43 PM
  #39
97rs4life's Avatar
Yea I was wondering about the NB setup as well. I probably will just delete the code, but would be nice to know.
Also where to tap into the setup in order to run a wire for hptuners and such.
Old Jun 14, 2007 | 12:25 PM
  #40
joehawkz71's Avatar
this is exactly what i thought i only have one used as well....
