Window switch w/an A4 question
thanks fellas
thanks fellas
i would pill it for 5700 tops, you're probably out of your powerband and not worth it to risk spraying during a shift since the consensus is to not spray during a shift. from 5700 to 6000 will be a fast rpm jump and i doubt you will miss it. i had mine at 5500 and it worked fine.
