?nitrous buttons hooked up threw steering wheel?
Also how hard is it to hook up a two step activation system for a dry nitrous kit. say on at 3000 off at 6800 also to keep the engine free of limit switches on the throttle body.
My goal is to pass tech at the track with them not knowing about the nitrous!
OH yeah,***-- COPMAGNETLS1-- ***, the software for a window switch with 3k on and a choice between 5800 and 6300 with the first gear lockout should be done tonight. The one with the fully adjustable on, off, and cylinders will be a little longer. Ignition noise is giving the chip trouble trying to read the RPM tables, but the afore mentioned one should be done real soon and a lot cheaper then the fully adjustable one. I could even put in costum values to choose from like if you wanted 2800 on and a choice of 5950 or 6450. You call it, I burn it! Send me more mail. I'll fill ya in.
