how safe is nitrous equipment in vehicle ?
And N20 is not explosive like in the movie F&F. You can actually put fires out with it. Its NON-flamible. It has lots of oxygen in it and when it reaches a certian temp ( inside your cylinders) it releases that oxygen. Then its just add fuel. No programing eithor. If you have a hypertech or somthing you have to take it off, or at least pull the extra timming out that it put into the spark map. The more N20 you spray the more timming you have to take out and the smaller you plug gap needs to be.
Hope this helps a little.
Sorry, but you have to pull the bottle out every time you need to fill it, but good ideal.
