N20 wiring help?
How do I fuse my N20 components? The wiring diagrams I find here on the forum do not contain the fuse sizes, placement in the diagram etc. I have all my instuctions from Dave's but they do not show fuses or where to get my power from...I DO need fuses don't I?
Also, does anyone have pics of where they installed fuses and where they are tapping power from?
My system details...
Nitro Dave's Dual Stage Plate (78mm) on LS6
2 fuel noides, 2 N20 noids
FPSS
860 Automatic shut off bottle heater
NX bottle opener
Trick Dual Stage Window Stitch with an integrated Throttle Position Sensor
This is the diagram I'm starting to use as I like it's versatility, thanks to the creator of the diagram!!! Super job!
XOXO,
Ms Eliz
http://www.retrorelics.net/jim/Board...structions.doc
Use it for the low amp stuff. In my car it powers both stage relay controls, Heater relay control, purge (no relay), Line Lock (no relay).
For high amp stuff (noid power, heater power, opener power) I added a mini fuse panel (cheap 6 fuse one), and drew power for the lug in the battery tray fuse panel (Used 8-10 gauge jumper to the fuse panel).
FPSS
NX bottle opener
XOXO,
Ms Eliz
Ricky
FPSS
NX bottle opener
XOXO,
Ms Eliz
I couldn't do this install without this forum and all the knowledge I've gained by reading what you all have done before me...U R simply the BEST!
Thanks again to all!
