LT1 Wet Setups
Old Jun 21, 2007 | 06:23 PM
1997compT/A's Avatar
Default LT1 Wet Setups
Forgive me if the information is already out there but I've been using the search function as well as google and haven't found jack.
All I'm wondering is where you guys are getting the fuel from for a wet shot (can it be done from the fuel rail?) and if there is any real concern about the distance from the nozzle to the TB. I have the Ram Air box in so I can't quite get to 6" away and it's going to be mounted in the rubber boot.
Also, are there any brackets out there already made for mounting the bottle in the spare tire area or should I just rig something up myself? Ideas for mounting without drilling through the sheet metal on the floor?
Old Jun 21, 2007 | 06:38 PM
donkey mule's Avatar
From the fuel rail. I cant help you on the ram air, I dont have one. I have a Moroso CAI. I got my bottle mounted between the 2 rear seats that way I dont have to have a remote bottle opener or a remote psi guage.
Old Jun 21, 2007 | 08:02 PM
ZFan88's Avatar
You get your fuel from the schrader valve that's on the rear of the intake, a little towards the driver side, seen here.. http://shbox.com/1/fuel_schrader_valve.jpg You'll need a valve stem remover from an auto parts store. Unscrew that cap, pull the stem out, and screw in your fuel line that goes to the solenoid..takes 2 minutes
Also, you can use this bracket http://www.nitrousoutlet.com/catalog...product_id=963 to mount your bottle in the spare tire area. It's what I use along with this.. http://www.nitrousoutlet.com/catalog...product_id=693 It already has holes drilled to mount on the car and mount the bottle heater on the bracket, so it took 10 minutes to install and looks great. Here is a pic of mine, and I have less room being a convertible..
Old Jun 22, 2007 | 04:54 PM
SSBound's Avatar
i like that i was going to put mine like that
SSBound's Avatar
very scrective very very sneaky
