Experience with Zex?
Old Jun 19, 2007 | 01:30 AM
1997compT/A's Avatar
Default Experience with Zex?
I've been reading about the Zex computer and everything they advertise says it monitors your a/f and supplements more fuel based on this? Theoretically then, you shouldn't need a tune (with exception of adjusting timing). Does anyone have experience with this? Perhaps any comments or suggestions?
Old Jun 19, 2007 | 07:58 AM
BREWS02WS6's Avatar
Id like to know too
Old Jun 19, 2007 | 10:24 AM
Beer99C5's Avatar
From Nitrous Outlets site
Zex Nitrous Systems have an advanced, patented feature called Active Fuel Control. This features monitors nitrous bottle pressure and adds or subtracts enrichment fuel so the engine never runs too rich or too lean when you engage the nitrous system.
Sounds like its based on bottle pressure and not a vehicle O2 sensor.
Give Dave, Ray or Chris a call at Nitrous Outlet they sell Zex and are familiar with the product.
Old Jun 19, 2007 | 11:10 AM
xBROKEx's Avatar
i had one and its just a series of distro blocks and vacccum fittings, its nothing electronic
Old Jun 19, 2007 | 11:15 AM
Hennytime's Avatar
they are nothing great, just a marketing ploy. only "plus" is it has a electronic wot switch compared to the standard micro switch. big deal. they are low quality (ive seen a few on friends cars, after telling them so) id just go with a nx/dynotune kit
Old Jun 19, 2007 | 01:30 PM
Nitro Dave's Nitrous Outlet's Avatar
Do not get pushed in the wrong direction. That information is misleading. This is a marketing strategy on Zex's part. You will still need to check the tune.
This is my opinion...
Most Nozzles pull a bit of vacume on the fuel discharge. Depending on the amount of nitrous flow caused by bottle pressure the vacume pulled on the fuel discharge will change. So Zex is using this info and claiming that now bottle pressure will determain how much fuel the nozzle flows.
Ignore that...
Dave
Old Jun 19, 2007 | 02:10 PM
BREWS02WS6's Avatar
Thanks for clearing it up, wont be going w/ Zex!
Old Jun 19, 2007 | 02:16 PM
No problem. Its a good system and great for beginners. Im not knocking it. I just dont want you having the assumption that you do not have to worry about the tune.
Dave
 Michael S. Palmer
Old Jun 19, 2007 | 08:09 PM
Damn...I wish I would've understood that before hand. It sounded like it monitored your a/f so I figured it would at least be a safe back up to your tune. Already bought it though.
So, what exactly does their little "brain" box do?
Old Jun 19, 2007 | 11:23 PM
Transam275's Avatar
uno wut i have zex and ur outta ur god damn mind to say that its low grade first of all its and 800 dollar system second of all its safe and ive had no problem at all and ive been eatin **** up wiht just a 75 shot im sorry im not tryin to start **** but find out from experience dont always listen to what everyone says unless theyve had it im happy with mine and i ino im doin better than 75 ill get it dynoed and let uno ill be pm'n u at jbutta224
Old Jun 20, 2007 | 01:05 PM
1bdbrd's Avatar
First, learn proper English and then implement that in your posts. Maybe you will be taken a bit more seriously.
Second, you are telling the man that SELLS the kit that he doesn't know what hes talking about?
Old Jun 20, 2007 | 03:45 PM
curtisad's Avatar
I have no idea what you are trying to say??
Old Jun 20, 2007 | 03:46 PM
curtisad's Avatar
Transam275,
I couldn't understand a word you said!
Old Jun 20, 2007 | 04:21 PM
BREWS02WS6's Avatar
Word. Haha exactly what I was thinking.
Old Jun 21, 2007 | 09:01 AM
2002_Z28_Six_Speed's Avatar
I have had the Zex kit in my car. The TPS memory kept even after having the battery unhooked for a month. I prefer the traditional relay system though so I can build it my own way. Add stuff as I want. Know it is built correct.
I am thinking about using their alum housing to hide/protect solenoids of my choice and build my own system. Maybe just scrap the whole system all together. Any buyers? hehe
The Zex kit is ok. It seemed limited, though. You can put bigger and bigger jets in and at about 150-175 it doesn't make anymore no matter what jet you put in. Tried a NOS plate and still the same ceiling. Maybe it is the ZEX solenoids! I have no idea!
The Zex kit kept my motor safe. I can't complain too much. One cylinder went lean but the motor is still quite healthy.
One omen kinda bugged me though. When I got my kit in the mail, pieces of the kit were missing. Important ones. I complained and actually got called by some important guy from the company in Memphis. Parts drop shipped in 48 hours.
Old Jun 21, 2007 | 10:25 AM
xBROKEx's Avatar
rofl a 75 shot
Old Jun 21, 2007 | 10:43 AM
75 shot is jack.
Old Jun 21, 2007 | 11:13 AM
Hennytime's Avatar
i helped put 3 systems in 3 different cars. the parts are low gfrade and the nuts and bolts are easy to strip and turn. maybe you think its high grade because youve never delt with high grade. every one of them i na year switched to a nx system and it was night and day.
Old Jun 21, 2007 | 04:24 PM
DropShipDave's Avatar
I ran a zex kit on my civic before I went turbo on it.. It was a easy kit to set up. I liked it. The stock clutch didn't =P
Old Jun 22, 2007 | 06:36 PM
99FRC's Avatar
I fell for that too, 'cause I was a NOOB!! However, I have not been dissatisfied with the ZEX kit. It sprays right, the built in WOT switch is nice and it was easy to install and set up. Great for beginners!! With that said, I'm already thinking about switching to the NX solenoids and Nitrous Outlet trick window switch. It's just cooler stuff, I feel better about the high end solenoids (can't afford new motor with 3 other mouths to feed) and I need a f'in first gear lockout! Other than that, the ZEX has been fine. IMO
Good luck, whichever you decide!
99 FRC
