nitrous wiring
Old Jun 22, 2007 | 12:23 PM
cammed00z's Avatar
Default nitrous wiring
Hey, ok i was wiring up my nitrous and ran into a problem......i had everything the way it goes or atleast i think, and i pushed my WOT switch with out the bottle in to make sure the solenoids were gonna open before i ran the nitrous. As soon as i did that my activation switch burned out.....It was a cheap switch from autozone...so my question is, do i have soemthing wiried wrong or could it have just been a cheap switch?
Old Jun 22, 2007 | 01:10 PM
Beer99C5's Avatar
Are you going through a relay?
Be careful activating the nitrous noid for a long period with no nitrous flowing through it. The Nitrous Noids generally rely on the nitrous for cooling while they are open. Activating them for more than a couple seconds without nitrous flow may void any warranty.
Old Jun 22, 2007 | 01:41 PM
cammed00z's Avatar
yea i got the relay....its a 3 prong toggle switch, i got power and ground to it then coming from the relay i got it hooked up to the middle prong.....the switch has a little light on it when its on....before i hooked up the line from the relay to it it would light up just fine....once i hooked it up and hit the WOT switch i guess it blew the switch cause it wont light up anymore....i checked to see if i had burned wires or something but nope.....i pulled the switch and put power to it straight from the batttery and grounded it so see if it turned on and it didnt.
Old Jun 22, 2007 | 01:46 PM
Todd157k's Avatar
make sure you have POWER on one side, GROUND on the other. Your wire to the relay is in the middle.
Post your schem. If the switch is wired correctly, it would probably be the relay is wired wrong.
Old Jun 22, 2007 | 02:11 PM
cammed00z's Avatar
Ok well it looks like this (http://i73.imagethrust.com/images/1V...h-a-relay.html) but instead of the window switch i went straight to a ground cause i dont have one....i did uses the middle terminal for the relay then power and ground for the other 2 prongs....I dont think the relay is wrong but im not sure i just followed a diagram like that one.
Old Jun 22, 2007 | 03:47 PM
Todd157k's Avatar
hopefully you mean you "went straight to ground" with the orange wires (pin 85) shown. Since you don't have a ws, the extra red wire going to the ws wouldn't be there. Assuming that, you must have the relay wired wrong cause even a cheap switch will handle the current.
Old Jun 22, 2007 | 04:11 PM
cammed00z's Avatar
right pin 85 went straight to ground and no i dont have the extra red wire.
Old Jun 23, 2007 | 09:49 AM
SmaknaSS's Avatar
If your using this diagram as reference. http://i73.imagethrust.com/images/1...th-a-relay.html
Where is your power going to on terminal (30) on the relay coming from? is it being fed through the arming switch? If it is you probably don't want top do that. BTW some switches are wired internally where the common of the switch is at the end of the switch instead of the middle of the switch. This type of switch typically has the common at one side of the switch and the other terminals close to each other. Typically the switch is wired to where the common is in the middle of the switch like shown in the diagram but if you have one of the type of switches to were the common is at the side of the switch and you wire it like the diagram you will short your power to ground through the switch. If you post a pic I can take a look at it. also (with the power disconnected) You can use an ohm meter to check continuity between where the power is fed to your switch, to your system and to ground. On a side note try disconnecting the ground on the switch as a test.
Old Jun 23, 2007 | 01:47 PM
cammed00z's Avatar
Pin 30 goes to my battery with a fuse inbetween the relay and battery....yea my WOT switch is labled so i know its not that its wrong...the switch that burned out is my activation switch some how it got overloaded but i dont know why.
