NEW PRODUCTS, Black Series Display Controllers.
Originally Posted by Nitro Dave's Nitrous Outlet
I love it........ Did you get the car fixed?
Dave
Dave
Sure they come out a month after I buy my FJO stuff. Don't get me wrong FJO is good stuff but theses have a few more features that the FJO's don't like a built in FPSS and A/F cut-off. Sweet gauges and Trick Performance is a great company to work with.
Eric
Eric
Ok guys. I am getting tons of calls and pms from people that are excited about the gauge's but confused by what all it can do since it has so many options. I am hoping this post will clear some of the confusion up. Feel Free to ask any questions.
THE V GAUGE.
Out of the box this gauge will offer the following fuctions.
1.NITROUS VOLUME USAGE.
2.AIR/FUEL READING. (Plugs into your wide band)
3.NITROUS SYSTEM SHUT OFF. (Shuts nitrous system of in relation to air/fuel readings)
4.Bottle Pressure gauge(Requires you buying sensor # SHP-1500- $60.75)
5.Nitrous Shut off ( You have to be using option #4 with the sensor for this to work. If bottle pressure is to high system relay will not triger)
OK,
Now that we see what it does out of the box lets talk about add on features. You are allowed to monitor one pressure using all the features that the gauge offers out of the box. This pressure has to be bottle pressure. If you do not have a wideband and do not need the gauge to be used as a wideband gauge you can use the gauge to monitor two pressures instead of one. So now you can add a second pressure to monitor. All the add on features require you buying the needed pressure switch.
Here are your pressure other options.
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
4.A SECOND NITROUS PRESSURE
5.WATER/COOLANT TEMP
6.OTHER (any other pressure option you may need)
NOW THE P GAUGE.
Out of the box the P GAUGE offers alot of options.
1.PROGRESSIVE CONTROLLER ( Multipoint ramping with RPM and Time base options)
2. SHIFT LIGHT
3.WINDOW SWITCH
4.TPS ACTIVATION SWITCH
5.FIRST GEAR LOCK OUT/DELAY OPTION (Aids in traction limitied applications)
6.AIR/FUEL READING (Plugs into your wideband)
Ok now that we have went over what the gauge does out of the box lets go over add on features. The P gauge is designed so that if you have a digital out put wideband such as the new FJO series you can use the built in digital input that the gauge has. This now free's up a area giving you the option of adding a pressure to monitor. (You will need to buy the needed pressure switch)
Pressures you can monitor are.
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
4.NITROUS PRESSURE
Guys let me know if you have any questions at all.
Dave
THE V GAUGE.
OK,
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
NOW THE P GAUGE.
2. SHIFT LIGHT
3.WINDOW SWITCH
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
4.NITROUS PRESSURE
Dave
Originally Posted by NXRICKY
NOPE see signature. I just like checking the boards out. My consulting business has been fun so far. I figured no need to change the signature, seeing how I am the most informed on NX products, and I like helping people.
Ricky
Ricky
Hello tech members. Thanks Dave for the posting on the options of the gauge. I can answer any questions yall may have about these gauges, but I can not post any PRICING. I am here only as tech support.
The pictures in this thread do not do these unit justice. It is hard to get an exact picture of this gauge. Like trying to get a picture of a computer screen.
You program the gauge buy the controll button. There is a small dial/button on the side of the screen, its hard to see in the pics look just the left of the screen. You simply push the button in to enter the programming menu's, move the button up, down or in, depending on what you want to do. Set the gauge up to fit your specs and then EXIT/SAVE and your done.
The Dispaly Controller has the computer already built in.
Yes in this pic you can see both pressures are being displayed. IF you have a wide band with programable output you can trade the fuel pressure for air/fuel reading.
Sorry I can not post pricing sorry not a sponsor. I can answer any other tech question.
Thanks for the kind words.
Originally Posted by Vetal
How it is programmed?
Does it alarm in lean condition only during spraying, or during other WOT operations as well?
Originally Posted by fastlt1
So will the v guage display fuel pressure and nitrous pressure at the same time with the correct sensors? How much does fuel pressure sender and nitrous pressure sensor cost?
I posted the prices right above the gauges
Dave
#35
Originally Posted by My90Iroc
The P is the same as the V where it's either a/f reading and 1 pressure or no a/f and 2 pressures?
The P gauge can read one pressure and one wideband ONLY if you are using the FJO 4xxx series widebands.
The P gauge has a digital port that is used for that function.
IF you do not have the FJO 4xxx series then you are limited to 1 pressure OR air/fuel. NOT 2 pressures.
#36
No,
#37
Damn, that sucks since I have an innovate LC1. Nice product regardless.
Dave
#38
I am currently running an AutoMeter electric N20 pressure gauge (2 1/16) in my dash right now.
*Can I use the same sending unit for the N20 pressure monitoring
*What do I need to purchase if I want to monitor A/F also
*I am assuming that to show the heater on/off it just requires a signal from my heater switch .... or does it require something else?
*What about if I want the option to cycle thru to monitor fuel pressure.... what is required
*What additional sensors are required to calculate bottle level (calculating for purge as well)?
#39
1 Can I use the same sending unit for the N20 pressure monitoring
2 What do I need to purchase if I want to monitor A/F also
3 I am assuming that to show the heater on/off it just requires a signal from my heater switch .... or does it require something else?
4 What about if I want the option to cycle thru to monitor fuel pressure.... what is required
5 What additional sensors are required to calculate bottle level (calculating for purge as well)?
2. Any wide band that has a programable analog output. 5v ramp where
.05v= 10AFR
4.5v = 20AFR.
3. NO, the guage controlls the heater, when you enable the heater( through the gauges control screen) you will see the heater icon pop up. IF the ICON is red its on, grey means its on but is at pressure, an X over the top of the ICON means there is an error. Either pressure is not rising, or somthing else is wrong.
4. IF you want fuel pressure you just need another sensor, that is rated for your psi. Most efi cars will use a 100psi sensor. IF you are using fuel pressure you can not use air/fuel.
5. None, the V guage can calculate the useage without a sensor, it is more accurate with the sensor in place though. We can monitor pressure drop which changes the amount of useage.
The V gauge can monitor useage of 2 systems. So there is a wire that will attach to your stage 1, and the other wire attaches to your stage 2/ purge valve.
Good questions by the way, let us know if there is anything else we can help you with.
