NOS Mini Controller ???
Old Jun 26, 2007 | 02:14 PM
DiabloFormula's Avatar
Default NOS Mini Controller ???
Does anyone know if when this controller is in resume mode with a delay time of say...1.5 seconds and you have the nitrous shut off at 6100 rpm's, does the controller start over once you shift into another gear or does it resume back at 100% nitrous where it left off, basically I want to use the delay timer as a first gear lock out and some of second gear hence having the delay on for a second or two, but what I'm confused about is does the cycle resume even after you've completed it or does it reset.
Old Jun 26, 2007 | 02:46 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
it will depend on how it is set...the NOS box can either pause the ramp (start over where you let off) or start the ramp over.
copied from the instruction manual:
STEP P. RAMP PAUSE MODE – (This mode will allow the NOS 2 Stage PROGRESSIVE CONTROLLER to either reset or resume the progressive nitrous ramp, that has been programmed into it. In reset mode, the ramp will start over from the beginning when the trigger has been deactivated and reapplied. In resume mode, once the trigger is deactivated and reapplied, the ramp will return to the last point that the system was active and continue the ramp from that point. NOTE: The NOS 2 stage Progressive Controller has a built-in 30 second time out. This means that after a total of 30 seconds of activation, the controller resets itself. This allows ample time for dyno runs or dragstrip runs to occur, without the controller shutting off prematurely. NOTE: If the system has completed the ramp and has not reached the 30 second time out, the user can reset the controller by pressing the left (#1) button and the display should then return to (r r) NOTE: This can only, and should only, need to be done when the controller is in Resume Ramp Mode! B C determines if the ramp is restarted or resumed when the trigger is reapplied. 0 0 = unit is in reset ramp mode (restarts with loss of trigger – starts over) 0 1 = unit is in resume ramp mode (resumes back to where it was when trigger was lost – Has to be reset before the next run, only if the system has not timed out).
