4l60e & 150 shot
Old Jul 1, 2007 | 06:39 PM
ja02ws6's Avatar
Default 4l60e & 150 shot
Stock T/A with 4l60e & 150 wet shot on or off when it shifts?
Old Jul 1, 2007 | 06:49 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I sprayed my 02 Z through the shifts and didn't have any problems
Old Jul 2, 2007 | 01:26 AM
JETBLACK's Avatar
The stock tranny is stronger than you think. I had wear on mine and it would hit the rev limiter on the 2-3 then finally shift and I sprayed through the shifts trying to kill it and couldn't. I have killed a bunch of built ones though.
Old Jul 3, 2007 | 02:09 AM
01_ram-air's Avatar
I spray through the shifts.
Old Jul 3, 2007 | 02:15 PM
Jpr5690's Avatar
Off Will Be Safer But It Is Really Gonna Come Down To Traction, Trsanny Tuneing And Your Other Mods
You Should Get Away With It On A Nearly Stock Car But If Your Already Heavly Modfied A Stock Tranny Is Already On Borrowed Time N20 Of Any Sort Will Fry It
Simply Put I Dont Think A Stock 4l60e Is Much Good Past The 400-450 Rwhp Range
Old Jul 3, 2007 | 02:36 PM
z28hustle's Avatar
thats because its not...
Old Jul 3, 2007 | 03:22 PM
99Z28camaro's Avatar
just use a window switch
Old Jul 5, 2007 | 10:42 PM
BriancWS6's Avatar
If you want the best times, spray it through the shifts. If you want to give it a better chance of holding up, use a window switch and have it turn off before the shift.
FWIW, when I had my a4 car, I didnt spray through the shifts.
Old Jul 6, 2007 | 12:37 PM
CAT3's Avatar
Restricted User
You can spray thru them, the question is how long? Everyone seems to have a better stock trans than the last guy. The stock trans will eventually let go, and when it does using nitrous, there is little warning, it'll just happen one time.
Old Jul 9, 2007 | 12:06 AM
mrr23's Avatar
i've always sprayed through the shifts on my cars.
Old Jul 9, 2007 | 10:40 AM
ShiznityZ28's Avatar
If you don't want to rebuild it turn it off. if you spray a heavy car through the shifts its gona wear the clutches out.
If you don't mind rebuilding it then it will go much faster on!
