FAST 90/90 and nitrous
Old Jul 13, 2007 | 07:45 PM
Robert56's Avatar
Originally Posted by brad8266
**** I saw a 150 shot cobra metal intake blow into pieces on a dyno. It can happen to any intake.
True, but not as common. I have had a few back fires through the traditional plenum above the runners, cast steel, center location carb intakes, and all have survived. Two problems on the efi cars conspire to cause a bad explsion, plenum below the runners, so mix has a harder path to follow and drop out ensues; the entry point is at the front of the intake which when a backfire starts expanding no easy escape, so it finds the path of least resistance which is through the plastic walls (sometimes metal or aluminum).
Robert
Old Jul 14, 2007 | 07:49 AM
bluecamaroz28's Avatar
Guys are you saying one should not spray through his expensive ported fast and should get Edelbrock EFI Vr Jr intake to be on the safe side.
Old Jul 14, 2007 | 08:51 AM
Robert56's Avatar
No not really. Just keep on top of your kit and tune, or go dry. Backfires are not an everyday occurance.
Robert
Old Jul 14, 2007 | 08:57 AM
scalemaster's Avatar
well i had the dry my self and now I went wet so I need to tale it to the track to see how it work I also got the car tune for wet gas will see and I also have the 90/90 set up
Old Jul 16, 2007 | 09:45 AM
striker754's Avatar
any other opinions? i dont know if i want to shoot a wet kit through my expensive intake
Old Jul 16, 2007 | 10:09 AM
Noyzee's Avatar
8 second mod
i run a ported fast with a nick williams t-body, i have run one for years now. with a 400 direct port and now with a plate kick.
so far so good. the burst pannals do not work. i saw an intake with them blow up, and the bottom was in perfect condition, burst pan and all. lol
a back fire will distroy any intake.
the fast is what i would run on any street car or even race car witthe 600-700 number in mind.
i will be going with a vic this winter on my car, but with the big power and big cubes, i need it now with a big t-body on top.
Old Jul 16, 2007 | 10:19 AM
BadAssFast's Avatar
More of the same...I use a Fast 90/90 Nick Williams and a Nitrous Outlet plate with a 200 shot.
It's just an intake anyway. It's not like you're holding a loaded and cocked gun to your head. Be smart and informed and you'll have a bunch of fun.
I am just now swapping to a DP after 3 years of nozzles and a plate. I didn't even buy the burst panels. I doubt you'll find a better choice for an intake for what its sounds like you are doing.
