200 Shot on a cammed 6 spd
Old Jul 13, 2007 | 09:54 AM
99Ws6TransAm's Avatar
Default 200 Shot on a cammed 6 spd
Hey guys, i shot a 150 (NX Wet) Last year on my stock internal motor. Didnt have any problems....with the bottle pressure up it ripped. Well now the cars got a torquer .v3 cam in it. Car runs really strong on motor. I was contemplating hitting it with a 200 shot. I have a full nx wet kit, fpss, wot switch, ngk tr6 plugs, bottle heater, remote opener, racetronix fuel pump w/updated harness, bmn window switch(having some issues), purge. I have it tuned so when i activate the system it pulls timing.
Car is a full bolt on 99 m6. Stock internals! Is the do able? Or is it really pushing the breaking point? Thanks!!
Old Jul 13, 2007 | 10:02 AM
RobbieTransAm's Avatar
I am in the same boat as you. I was thinking 150 on top of my current cam only power, but I really want to try a 200. I most likely will use a dedicated nitrous fuel system, either way. I am willing to risk 600+ on the stock bottom end. Everyone says it's all in the tune.
Old Jul 13, 2007 | 11:27 AM
123sugey's Avatar
I've been running a 225 shot ( dual staged) for 2 years. Stock 97 ls1 w/ 120,000 miles !! I think your setup will be ok.
dual stage it ..........
Old Jul 13, 2007 | 11:29 AM
what all does it take to convert a single stage into a dual?
Old Jul 13, 2007 | 11:34 AM
123sugey's Avatar
W/ your system you need another nozzle and fittings. You can look in for sale section and pickup the nozzle and lines/fittings cheap.
Old Jul 13, 2007 | 12:13 PM
01FormulaTA's Avatar
if you go dual stage get a plate system, and also upgrade your injectors to some 42's as the stock ones are prob maxed out......
Old Jul 13, 2007 | 04:33 PM
HolyShiznit's Avatar
It's a wet kit he is using....so the injectors don't mean anything. It's being pulled off of pressure at the fuel rail.
Old Jul 13, 2007 | 04:45 PM
Phlip00WS6's Avatar
Holy Shiznit!!
