150 wet hit from a dig?
Old Jul 16, 2007 | 09:42 PM
99Ws6TransAm's Avatar
Default 150 wet hit from a dig?
I have a BMN window switch, with the first gear lock out. It somehow isnt working and im afraid once i go to launch its gonna blast the spray. Whats a safe way to launch the car with a 150 hit, and not doing damage? This is a full bolt on/cam 6-spd car.
Old Jul 16, 2007 | 11:09 PM
SSDriver's Avatar
make sure you have the clutch slightly out so there is a slight pre-load on the tranny and rearend and slip the clutch out. Its the slack and the sudden jolt of the teath hitting each other that will break stuff.
Old Jul 16, 2007 | 11:14 PM
waterbug1999's Avatar
My 1st gear lock out did not work at 1st due to me having the spray turn off to close to the shift points.. So, it would shift before it saw the RPM's I set it at.. Not sure how it would work on your 6 speed but what are you shifting at and what do you have the spray turning off at?
Old Jul 17, 2007 | 12:43 AM
calongo_SS's Avatar
1. Remove 10 bolt
2. Install 9"
Really if you're on street tires you'll just blow roast them and shouldn't hurt anything. If you're on slicks you might brake something without the bottle.
Old Jul 17, 2007 | 08:26 AM
I think i have it set to open at 3200 and ruffly shut off around 5800. Im shifting around 6300.
Originally Posted by calongo_SS
1. Remove 10 bolt
2. Install 9"
Car has a 9" in it already The run will probably be on the street with a 315 nitto...or a 315 mickey thompson.
Old Jul 17, 2007 | 11:04 AM
calongo_SS's Avatar
Don't worry about it then. What did you buy the 9" for if not to beat on it?
Old Jul 17, 2007 | 11:49 AM
Zero4488's Avatar
Restricted User
I say just go to the track and see what happens....why put all this **** on a car if your not going to use it...and whats the worst that can happen? Something breaks?
Old Jul 17, 2007 | 12:40 PM
SSDriver's Avatar
if you have a 9" just spray the damn thing out of the hole.
Old Jul 17, 2007 | 12:45 PM
brad8266's Avatar
Damn I mean thats the idea of the 9", beat on that ******.
Old Jul 17, 2007 | 12:46 PM
i didnt mean to word it that way lol. Im not worried about the rear at all. im asking what should i launch at? I dont wanna have one of those magic *booms* come from the intake from it puddling up or somethign else.
Old Jul 17, 2007 | 12:53 PM
calongo_SS's Avatar
3k or higher. Assuming you have a WOT switch & you launch above 3 k you shouldn't have any fuel puddling problems.
Old Jul 17, 2007 | 12:54 PM
brad8266's Avatar
Use a window switch and set it to activate at no less than 2800 RPM's, youll be fine. The puddling is not as common as you may hear on the net. Once you launch and catch traction, floor it and it will activate once you get up in the rpms.
Old Jul 17, 2007 | 01:35 PM
Zero4488's Avatar
Restricted User
3k or higher sounds fine...
Old Jul 17, 2007 | 02:19 PM
I do have a WOT switch. Mounted off the TB.. So if i launch the car between 2800-3000 rpms..have the window switch on my BMN box set to 3200rpms..it should be alright to spray off the dig?
Old Jul 17, 2007 | 02:21 PM
brad8266's Avatar
should be fine
Old Jul 17, 2007 | 02:33 PM
Wooo...this is gonna be a ride in this car. 6 spd full bolt on cam 9" with a 3.90 gear ratio. Hmmmm
Old Jul 17, 2007 | 03:40 PM
bad6as's Avatar
what size cam?
Old Jul 17, 2007 | 10:16 PM
Well i got out with the spray tonight. Unfortunatly the bottle was alittle low..so i was only at about 800psi. I decided to just to go from a roll. The spray was there..but definitly not up to par due to low psi. Everything ran good though..so once i get that PSI up..its good to go!
