225 hit-what should i be happy with in rwhp
Old Jul 17, 2007 | 07:58 AM
njc.corp's Avatar
Default 225 hit-what should i be happy with in rwhp
hello-members-
putting in 225 hp pills this weekend on my ls1.
on 175 spray made 525-540 bhp on 950-1050 bottle pressure
what should i get or be happy with on the 225 spray
i have all the requirements-fuel pumps,bottle heater,etc,etc
tuner reckons he will take 4 degrees out for the next 50 hp spray--
its a zex direct port wet system-engine is stock stanndard apart from heads,cam,springs,fast 90/90 --36 pound injectors--1-7/8 pipes+3 inch dual system,750 hp clutch,3.73 ratio
any answers would be nice-
Old Jul 17, 2007 | 07:59 AM
brad8266's Avatar
well a true 225 shot should be what your NA HP is + 225HP
Old Jul 17, 2007 | 08:03 AM
99Silverado5.3's Avatar
Also, will depend if your kit is rwhp rated or flywheel. I see you have BHP not rwhp. So, take into factor if your kit is rated @ the flywheel or wheels. But, yes, a true 225rwhp shot will net you 225rwhp+ N/A rwhp.
njc.corp's Avatar
so around 575-585 bhp? if so its not much of a gain though?
maybe 1 should spray the whole 300 on it if i am only chasing a gain of 25-35 bhp?
Old Jul 17, 2007 | 08:06 AM
njc.corp's Avatar
sorry-my fault-on 175 spray it makes 525-540 rear wheel horse power.
from memory when i bought the kit the salesman who sells zex down here said it is a 300hp engine rated kit-wet-direct port
Old Jul 17, 2007 | 08:12 AM
What did you make without nitrous?
If you are making 525rwhp on a 175 shot that is rated @ the wheels or in other words a 175rwhp shot. On a true 225rwhp shot, you should make 575rwhp. A true 300rwhp shot you should be 650rwhp. If it is rated @ the engine should be ~30rwhp less than stated.
Just a little confusing because bhp is at the motor. RWHP is where it's at. bhp is obsolete to me unless it is on the water or air.
Good Luck
Old Jul 17, 2007 | 08:23 AM
njc.corp's Avatar
okay
n/a 415 rwhp
on 175 engine spray it makes 527 rwhp on 940-950 psi
same as above on 1050 psi 542 rwhp
Old Jul 17, 2007 | 09:19 AM
Ok, that is at the engine. Based on what the 175hp hit did, should be around 560rwhp on the 225hp, 610rwhp on the 300hp.
Old Jul 17, 2007 | 09:59 AM
njc.corp's Avatar
thankyou-not much of a gain on the 225 spray-i will see if we can spray the whole 300hp in it-
Old Jul 17, 2007 | 10:04 AM
TINKRD's Avatar
all that being made on stock pistons/rods? sounds like a ticking time bomb to me.
Old Jul 18, 2007 | 01:17 AM
njc.corp's Avatar
maybe-maybe not-
i have done everything right.
i have done everything u can think of-fuel pumps,timing+tune+plugs +gap etc etc
been hitting 175 for over 6 months straight-so far so good-
new engine to suit nos is due in dec 07-will c if it last this long-
i have also made a mistake-their is no zex 225 spray-next one is 200+ 250 and then 300 hp
Old Jul 18, 2007 | 01:44 AM
99DWPTA's Avatar
**** it do a 300 and tell us how she pulls
Old Jul 18, 2007 | 06:27 PM
njc.corp's Avatar
thats what i said to my computer guy-he reckons we creep on it and see how she goes-
it would have to move along with 300hp spray if it holds up?
Old Jul 18, 2007 | 06:43 PM
wannasupra's Avatar
a 300 shot would be a little retarted. go for it, get video.
Old Jul 18, 2007 | 08:41 PM
white mongoose's Avatar
wow ur not scared that u might blow up ur engine cause thats alot of nitrous ur car is taiking, well good luck and let us how did it go
Old Jul 18, 2007 | 09:05 PM
njc.corp's Avatar
NO NOT REALLY-ITS PERFORMANCE AND **** HAPPENS-NOTHING IS 100% EVEN FULLT RACE ENGINES HAVE ISSUES.
I HAVE DONE EVERYTHING THAT IS RECOMEMENED TO USE 300 HP SPRAY-
UP TO THE ENGINE AND TUNER-
WILL HAVE RESULTS BY NEXT FRIDAY-IF IT MAKES OR BREAKS-
IF IT SURVIES I WILL RUN IT THE FOLLOWING WEEK WITH 175 TO PUT A NUMBER ON BOARD-I DONT WANT TO JUST SAY IT MAKES POWER WITH JUST A DYNO SHEET-
I HAVE THE NEW 400-427+N20 DUE IN DEC 07-SO I AM LOOKING FORWARD TO THAT-
WILL C IF THE ENGINE MAKES IT TO DEC-=MAYBE
Old Jul 18, 2007 | 09:19 PM
408 z28's Avatar
thats what i was thinking make sure you get i video of that thing on the 300 pill on the dyno... good luck and hope it holds up for ya...but i doubt it
Old Jul 18, 2007 | 09:39 PM
koolrayz's Avatar
spray the house down. guys been spraying the stock ls1's with 250-300 shots for a long time and they seem to take it,,,,,, untill there is a little hiccup with the tune.
Old Jul 19, 2007 | 02:54 AM
showoff's Avatar
atleast break the 300hit up in stages, or add in a progressive controller 2 better your chances
