35 gap hurts n/a performance
Orange Crush...Just and FYI if you are getting surging at idle or partial power...but are fine at WOT its unlikely its a plug wire. The more air and fuel you pack into your cylinder the worse an ignition problem will become. What is barely noticable at idle should become pronounced at WOT.
Orange Krush...Just a FYI if you are getting surging at idle or partial power...but are fine at WOT its unlikely its a plug wire. The more air and fuel you pack into your cylinder the worse an ignition problem will become. What is barely noticable at idle should become pronounced at WOT.
It is just at idle in gear, everywhere else it is just fine, but I did notice it right after doing plug change.
355/360 motor and 445/485 on the 100 shot. Do you think I can gain a little more power by gapping them to say .42 +/- a few?
285lbs here.. I want to weigh 300lbs by X-Mas...
