just installed kit . i have a few questions
Old May 15, 2003 | 09:18 PM
GM's Avatar
GM
Default just installed kit . i have a few questions
i just installed my nos dry kit i am running the 75 hp jets right now to play it safe until i get on a dyno to check the a/f ratio with the 100 hp jets .i have a few questions .1) i have a window switch set to start at 3000 rpm and stop at 6000 rpm . is 3000 too low to start spraying? 2) i have ngk tr6 plugs gapped at 35 is this a good gap ?thanks
Old May 16, 2003 | 03:15 PM
GM's Avatar
GM
Default Re: just installed kit . i have a few questions
anyone?
Old May 16, 2003 | 05:04 PM
Symonsyz1's Avatar
I have mine set at 3200 rpm right now. I wanted to be on the safe side when i sprayed the first time. I just got done with the install and sprayed yesterday. Most people have theirs set at 3000 rpm. So you should be set to go. I think most n20 companies say spray above 2500 rpm.
Old May 17, 2003 | 09:50 AM
GM's Avatar
GM
thanks . anyone else with a nos dry kit have any advice? i only have the 75 hp jets in and it still makes a big difference. in general the spray is fun.the first night i put it in i roasted a z06 from 0 to about 120 and i had really poor bottle pressure.i was a little suprised how far i walked on him myself .now i have the bottle heater working and it hits much harder.
Old May 18, 2003 | 11:05 AM
Ed Blown Vert's Avatar
3K is fine.
Old May 18, 2003 | 01:52 PM
unit213's Avatar
Administrator
3K rpms is perfect. Your TR6's will be fine too.
Old May 18, 2003 | 08:22 PM
GM's Avatar
GM
thanks
