dry shot/bottle pressure/tune question
if i have my car tuned at the ideal pressure at 1050, and have the appropriate timing and fuel changes made, but when i go to spray the pressure is above or below will it effect how my car runs negatively? knowing the higher the pressure the more it flows and the inverse, since the nitrous is passing through the maf, will the injectors input the right amount of fuel even if its not on the same pressure it was tuned at?
Oh one other benifit of starting with a lower b/p is the fact that you'll drop less pressure per run.
Robert
Robert
