Nitrous Backfire
for example, a T56 car is cruising at 3000RPM in 6th gear and goes wide open throttle it will not increase in RPM as fast as WOT in First gear at 3000rpm
When the kit is activated the motor must be able to build RPM fast enough to not allow the intake to "load up".
would you be lugging the motor too much for nitrous then in 6th gear at a little over 3500RPM?
how bout with a 3.23 A4? would you hit the nitrous at about 4000RPM in 4th at around 135mph?
in my 3.42 a4 v6 camaro (with top down and 75 dry shot), i sprayed 3rd to 115mph and 4th from around 120mph and the porsche i was racing still walked away. the motor was fine.
i don't think i'd try to wind out my LS1 like that though. i'd hate to melt my motor at that speed.
