ZEX nitrous kit install
Old Jul 22, 2007 | 08:08 PM
tom1025's Avatar
Default ZEX nitrous kit install
im installing a ZEX wet kit on my 2000 z28 with a MSD digital window switch and a fuel pressure safety switch....i have it wired with the diagram from the sticky up top but i dont know which wires to use to connect the TPS and tach....the MSD say pin 10 white wire but i wanted to make sure....the zex kit doesnt use a switch for WOT but hooks the the TPS to know when its at WOT....anyone know the colors and best locations to get these 2 wires? i am going to order a Nitrous outlets bracket to put it in the spare tire area...car makes 418hp N/A and im putting a 100 shot on it....should be a fun ride....also i am ordering a Kenny Belle boost a pump to give it more fuel....or would i be better off using a Racetronix pump?? right now it is stock pump and injectors
Old Jul 24, 2007 | 08:16 AM
tom1025's Avatar
im suprised no on has answered the questions yet
Old Jul 24, 2007 | 03:44 PM
John Junkins's Avatar
Tom1025,
The TPS wire is the blue one and the 10 pin white wire, Remove the cover and look at the retainer real close the numbers are on there. And I would soldier the wire connections. I just finished installing mine. Also don't forget about the relays you will need them. Trust me I found out the hard way. Good luck on your install.
John Junkins
