Setting up to heat while the bottle is closed, how?
Old Jul 22, 2007 | 09:06 PM
striker754's Avatar
Default Setting up to heat while the bottle is closed, how?
Can I just put a tee on the blowdown port or is that port special to hold the blowdown disc? I know you can set it up like this but is there a special bottle valve or how do you do this
Old Jul 22, 2007 | 10:26 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Get ahold of NX they may still have some of the old fittings to make this work. 11711 I believe was the number, worked only on female threaded NX bottle valves.
Other then that you will need a new valve.
