9 Second Nitrous Combos On Stock Shortblock
Old Jul 26, 2007 | 06:56 PM
MOSTDELUXE's Avatar
What was your suspension set up with the 1.3x 60's?
Old Jul 26, 2007 | 07:09 PM
next's Avatar
QA1 shocks (afco double adj are better if you plan on investing), QA1 adjustable front springs, stock rear springs, Spohn TA, BMR LCA'S and panhard (both adj.) all brought together by the Madman suspension tune
I took my car from a 10.4 down to a 9.8 without adding any additional power. Madman setting up the car's suspension was a huge help. You also need to understand that I took a LOT of track time with one adjustment at a time to sort out what the car liked best.
I don't think a lot folks appreciate how much time it can take sorting out a car and they make too many changes before a car runs it's full potential.
Old Jul 26, 2007 | 07:11 PM
next's Avatar
Originally Posted by wicho02z
guys i need help im new to this and would want to know what times i should be hiting. my set up is ms4, LT,ory, cut out, just installed rossler th400 with t-brake,stall at 3600, stock 10 bolt no gears. was a m6 so gears are at 342? think on go with tnt f1 kit. spraying 150, o and no fuel pump and injectors.
Not trying to be smart a$$, but your car will run whatever the timeslip says. You'll drive yourself crazy chasing some internet timeslip.
Old Jul 26, 2007 | 07:45 PM
MOSTDELUXE's Avatar
It seems alot of people say madman works wonders with the suspension. What does he do when he sets up a suspension ?
Old Jul 26, 2007 | 07:57 PM
MOSTDELUXE's Avatar
Iam trying to take it slow and change one thing at a time to see what really works. In the past ive seen people and myself run the car and then change 3 things and go back out and say well it went faster. But maybe one of those changes slowed the car down a tenth and the other changes picked up 3 youll never know. I was going to start with rear shocks and see what that does what do you think
Old Jul 26, 2007 | 09:30 PM
next's Avatar
My best suggestion is talk directly to Madman if you want to learn about what he does.
Good to hear the one change at a time approach.
Instead of rear shocks first, I'd suggest the front springs/shocks so you'll have adjustable perches that will allow you to four corner scale the car and set up the proper bias for a torque arm car. You'll want all the stuff eventually but I'd really suggest the SFC's to keep from twisting the car up.
Old Jul 27, 2007 | 07:27 PM
JDP's Avatar
JDP
Originally Posted by Silverado327blue
put a 4 inch stroke in it. 402
so when did the camaros come with an ls2?
4 inch stroke would make a stock bore ls1 a 382 if im not mistaken.
sorry, back to the topic now
