150 shoot on a lt1??????
Old Jul 24, 2007 | 02:06 AM
speedylexus2006's Avatar
Default 150 shoot on a lt1??????
i was wondering if this is the most i can do?
ALL I HAVE IS HEADERS,MALLORY 685,MSD COIL/WIRES AND M/T D/R
what would i have to do if i decide to do a 200??????????
EVERYTHING ELSE IS STOCK
Old Jul 24, 2007 | 09:37 PM
oner's Avatar
you'll also need a good tune(to adjust the timing for that 200shot), colder plugs and a little bit more octane.
-good luck
Old Jul 24, 2007 | 11:10 PM
krazy4's Avatar
150 shot will work, but not if you have the stock fuel pump.
Old Jul 25, 2007 | 04:03 PM
z28_mischief's Avatar
i'm thinking of running a 100 wet shot on stock motor, motor is running rich to begin with, so i'm thinking i'll be fine....what do you guys think?
Old Jul 25, 2007 | 04:29 PM
jakesz28's Avatar
150 is pushing the stock fuel pump. I have seen a guy spray 225 thru his but he ended up melting a piston because of a fuel problem(stock pump). I sprayed mine with 200hp at the wheels.About a month ago but then the rear end let go. So I may be going back to the track Friday.
I would get a Walbro gss307 or gss340 fuel pump. 255lph.
Just remember to pull 2 degrees timing per 50hp with your mallory 685. It wouldn't hurt to pull a little extra for the 200 shot and check the plugs.
Old Jul 30, 2007 | 08:58 AM
teezlr's Avatar
I have a stock 93' lt1 Formula, I have the 75 hp jets in right now and have yet to spray it. Can I run 100 hp jets without changing timing or plug gap?
Old Jul 30, 2007 | 04:27 PM
oner's Avatar
You must lower the gap on your plug and use non-platinum plugs like NGK's. Your stock timing is fine on a 100 shot just make sure you have atleast 93 octane in her when you're ready to spray.
-good luck
Old Jul 30, 2007 | 07:37 PM
derekderek's Avatar
I run a 150 shot with an NX kit with stock timing. But I do run higher octane with alittle meth mixed in. So I am sure that helps also have a wally 225lph.
Old Jul 30, 2007 | 10:34 PM
donkey mule's Avatar
I run a 150 shot and lowered my timing a couple of degrees as well as gapped my NGK tr6's to .035. My fuel system is stock but I know better than to push it any more!
Old Jul 31, 2007 | 01:12 AM
Ok Thanks Also I Did Run It With A 150 Shoot
Man Its A Huge Difference Off The Line I Cant Wait To Up The Rearend And Lca/panhard In The Next 2weeks
Old Jul 31, 2007 | 08:16 AM
nfa's Avatar
nfa
I ran a 150 shot no problem with a racetronix 255, 94 octane and autolite 104's gapped down to 42 or so. The stock clutch didnt like it too much tho.
Old Jul 31, 2007 | 01:18 PM
derekderek's Avatar
Just wondering if anyone has tried a bigger shot than 150hp? I have the fuel upgrades for it. Most of the nitrous safety equipment thinking of running a 175shot then try a 200hp shot just to see if it will handle it.
Derek
Old Aug 1, 2007 | 08:42 AM
WhyHelloOfficer's Avatar
Derek
Assuming you've got the correct a/f with proper jetting and timing retard, I don't see why you won't be able to spray more than 150. There have been people spraying 175-200 on the factory shortblock but most don't venture that far.
Regardless, that kind of a hit on a tired factory shortblock of an LT1 -- don't expect it to last forever.
Old Aug 1, 2007 | 09:03 AM
derekderek's Avatar
Yea I would'nt expect it to last to long with that size of shot. But I figured the rear end will go before the engine would. I am going to Iraq soon so I just want to see what she can handle / Get my thrill's out of her before I leave. But I think with the higher octane and Meth. proper timing it should be ok for a run just got to watch my fuel pressure and what not. I have autolite 103's thinking of going another step colder just for insurance. Any other suggestions?
Old Aug 1, 2007 | 09:12 AM
Double check you have a tight gap (.035") and that your a/f is good on a dyno. The 'recommended jetting' NX gave me for a 100 shot put me a little leaner than I would have liked. Every car is a little different, remember that.
If you plan on running some decent tire, then I'd be concerned for the transmission and rear end. I typically hit the kit after the 60' to try to minimize the stress on the drivetrain.
I usually run a 1/2 & 1/2 100/93 Mix when I spray at the track to be safe, along with three degrees pulled for the 100 shot. If you're going for broke, then who cares. Just sit down, shut up, and hold on. My setup is very conservative because I need my shortblock to survive another four semesters of college
God speed to you in Iraq. Everything you and our armed forces do is greatly appreciated
Old Aug 1, 2007 | 10:33 AM
1997compT/A's Avatar
JakesZ28, you previously said you had been spraying a 150 shot on stock timing but now you're advising to pull 2 degrees for every 50hp?
I'm going to spray a 125 shot (flywheel) and needed to know if I should be pulling timing from my stock setup or not.
Old Aug 1, 2007 | 02:05 PM
96lt1m6's Avatar
255 lph pump,150NX hit no timing retard on 93 octane.no problems
Old Aug 1, 2007 | 04:34 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
I would never suggest spraying more than 150 on a stock motor...can you yes but I would not. This is for many different reasons.
1) Flow characteristics of the stock manifold starts to have distribution issues above 150
2) The stock pistons are not going to enjoy the cylinder pressure, and any slight issue is going to have major consequences.
3) the factory fuel system was not designed to support that much power.
To run up to 200 shot on a stock LT1, would require upgrading the fuel pump, monitoring AF, and checking the plugs to verify distribution.
The 1-2* per 50hp rule for timing is just a base starting point. For a 200 shot I would pull 8-10* and monitor knock and the plugs while slowly adding timing back in. Most nitrous kits are jetted for stock timing and fuel pressure. Any changes you make to the vehicle might require adjustments to the jetting to maintain a safe AF.
Last but not least you must be willing to pick up the pieces when it breaks.
Old Aug 1, 2007 | 05:44 PM
jakesz28's Avatar
On my car I sprayed about 60 to 70 passes on a 150 shot with stock timing and no noticable problems. But when I hooked up the mallery 685 I pulled some timing and actually picked up a little MPH. So I must have had some knock and the computer pulled extra timing to get rid of it.
I have currently stopped the computer from pulling timing at WOT. So I pull 4* for a 150 shot and my timing is advanced some in the tune.
