Largest dry shot on stock injectors?
Old Jul 25, 2007 | 09:08 PM
Alt's Avatar
Alt
Default Largest dry shot on stock injectors?
Thats about the only other thing I need to know about my car before I finish up my install and get a few more odds and ends to clean it up.
Lid, full exhaust, LS6 manifold *on its way*, only performance mods car will have upon the initiation of the nitrous. I will be having it tuned before I just go out and spray due to my lack of having a WB. Though I wanted to know what is the largest shot I can run on my stock injectors, and I guess while I'm at it what would be the largest shot I can safely run on my stock fuel pump, with XX lb injectors. Safely run on my stock fuel pump.
This way if I decide to upgrade, I at least know what my limits are and how to raise those limits with the correct parts.
Current jetting is 100 shot, I assume its a rwhp shot, single NX nozzle at .052
*If this has been covered, search isn't working for me. Even with searching with the new search commands*
Old Jul 25, 2007 | 09:12 PM
Cam72aro's Avatar
I have heard 125-150 is the max on stock pump and injectors.
Old Jul 25, 2007 | 09:16 PM
Alt's Avatar
Alt
That is about what I had imagined, I appreciate the quick reply.
Old Jul 25, 2007 | 09:24 PM
Cam72aro's Avatar
No prob mang. I would watch the a/f and make sure that you are not getting ang kr. Also make sure that the nozzle is pointed in the correct direction and location in relation to the maf. I dont know alot about dry shots as I have always either sprayed a wet plate or a fogger. Its just easier and safer imo. Josh
Old Jul 25, 2007 | 10:19 PM
Robert56's Avatar
The math for sizing injectors can be found in the wet vs dry thread. It's based on power known, or power sought.
Robert
Old Jul 26, 2007 | 03:09 AM
TwistedSS's Avatar
My shot made 128 HP and 139 TQ on stock fuel pump and injectors. Single nozzle dry into the side of the airbox.
Old Jul 26, 2007 | 04:30 PM
Alt's Avatar
Alt
Now what about the stock fuel pump, what can that handle?
Old Jul 27, 2007 | 02:34 PM
suburbanlife866's Avatar
Just be safe and get and aftermarket fuel pump. Its around $160 for a LOT of insurance. Plus your gona need it if you do H/C later on. Might as well just do it now.
