NOS Bottle heater
Old Jul 31, 2007 | 08:34 PM
One Of Many's Avatar
Default NOS Bottle heater
I have a NOS bottle heater. I have heard that they don't work very well and that I should just use a torch. Does any one have one, If so how good is it?
Old Jul 31, 2007 | 08:42 PM
~RedLineLs1~'s Avatar
Mine worked fine....until one of the wires going into the heater ripped out (my fault). My HSW heater is a lot better but the NOS heater got the job done.
Don't use a torch...ever.
Old Jul 31, 2007 | 10:39 PM
TwistedSS's Avatar
Sometimes in the middle of winter even a good bottle heater wont even do the job...then its time to break out the torch
I am not condoning using a torch to heat a nitrous bottle.
Old Jul 31, 2007 | 11:56 PM
Dragman's Avatar
Get Harris Speed works heater it is a nice piece!
Old Aug 1, 2007 | 12:20 AM
speedylexus2006's Avatar
Mine Works Fine And It Takes About 10-15mins But It Sucks Of Course When There Is Little To None Left In The Bottle ..................
Old Aug 1, 2007 | 08:45 AM
WhyHelloOfficer's Avatar
So keep a spare bottle, or keep it more full. Nitrous isn't 'good to the last drop.' I rarely let my bottle get down to much less than 4lbs.
I'm running a Dynotune Heater Element wired straight to a switch, and I keep an eye on the pressure with the digital gauge. I haven't had any issues with it at all, and it will typically heat up pretty quick. Granted I'm in FL so I don't have to deal with super cold temperatures either
Old Aug 1, 2007 | 09:38 AM
Todd157k's Avatar
I'll bet the people that say heaters (any brand) don't work well, used small wire and didn't use a relay.
Old Aug 1, 2007 | 04:36 PM
Nitro Dave's Nitrous Outlet's Avatar
The NOS heater will work fine. Depending on which unit you have it may have a thermostat. Im not a fan of the thermostat. I would upgrade it to a better pressusre switch such as this.
http://www.nitrousoutlet.com/catalog...product_id=992
In the case of winter a good bottle blanket such as the NX blanket can make all the difference in the world.
Dave
Old Aug 1, 2007 | 07:57 PM
Cam72aro's Avatar
I had a nos bottle heater and wired it with a relay and heavy gauge wire. I used the thermostats that were supplied that kick it off at 85 degrees. I loved it thought it worked great. It kept the bottle pressure around 950-1000. It only took about 10 minutes to heat a 15lb bottle up.
Old Aug 1, 2007 | 10:52 PM
SSmoken's Avatar
i use a torch
Old Aug 1, 2007 | 10:54 PM
98nosz28's Avatar
I have the NOS one and did not wire in the thermostats. It works great but you have to keep an eye on the pressure.
Old Aug 1, 2007 | 11:00 PM
BobDoLe's Avatar
i love the 860 bottle heater/bracket.
it's like wrapping a fat electric iron around your bottle.
here it is on my previous camaro. i still use it on my ss, but its hidden behind the driver's seat.
Old Aug 2, 2007 | 03:01 PM
BayAreaSS's Avatar
I decided to ditch the thermostat too. I have a digital pressute gauge that i can look at. My Nos heater is very hot about 45 seconds after i turn it on. I havent filled my bottle yet to see how fast it heats up but i will next week.
Old Aug 2, 2007 | 07:05 PM
I think I might just buy the 860 bottle heater/bracket it looks really good.
Old Aug 2, 2007 | 08:53 PM
sprydncamd ta's Avatar
nasty hawk went fron the nos heater to the hsw heater and there is a huge differance in the amount of time it takes to heat the bottle up and it stays hotter longer
Old Aug 2, 2007 | 11:22 PM
donkey mule's Avatar
I use the Dynotune Auto bottle heater and like it.
