parallel
Old Jul 31, 2007 | 09:13 PM
jetblast's Avatar
Default parallel
has anybody tried wiring, the noids in series instead of parallel. wouldn't it be safer that way ?! or is it too much load for a window sw., couldn't a window sw. just power-up a heavy duty relay instead or is there too much lag time for that.
Old Jul 31, 2007 | 09:20 PM
Cam72aro's Avatar
When you say series do you mean positive to negative and so forth? If thats what you mean then no it wont work. A solenoid wont operation like that. As far as using a relay a window switch cant supply the amperage to operation a solenoid anyway. It has to be done that way. If you wire the noids off the window switch, you will burn it up.
Old Jul 31, 2007 | 11:40 PM
Todd157k's Avatar
it's voltage drop, and no, it won't work. You would have to operate them with 24v. Current would be the same.
