Should i be worried?
Old Aug 3, 2007 | 06:15 PM
LVCTSV's Avatar
Default Should i be worried?
My check engine light just came on today and the car has been backfiring quite a bit. but it is driving just fine...am i just running a little too rich right now???
Old Aug 4, 2007 | 12:52 AM
donkey mule's Avatar
Could be a # of things. I would check o2 sensors and or wideband radings.
Old Aug 4, 2007 | 09:43 AM
Matt@HSW's Avatar
Scan it and see what code it is. I think it's Autozone that will scan it for free.
Matt
Old Aug 4, 2007 | 10:47 AM
suburbanlife866's Avatar
I had the same thing happen to me. Got my LT's installed....car drove great....then while cruising around randomly....it seemed to misfire like a bitch.....then the car went crazy lean....then drove fine after. Check engine light on and everything....ended up being a bad O2 sensor.
Old Aug 4, 2007 | 08:54 PM
LVCTSV's Avatar
Thats exactly whats happening to me...all started after i threw on the LTs. But seems to be running fine all day today..its a soft code cause when i undo the neg battery ground it goes away. we will see what happens i guess.
Old Aug 4, 2007 | 09:03 PM
Jbmoney21's Avatar
Get it scanned and quit the guessing game
Old Aug 4, 2007 | 10:47 PM
98Camarod's Avatar
Sometimes the codes are not always right, just to let you know. We had a car at the shop that was throwing numerous codes, cam sensor, crank sensor, maf sensor codes, and a random misfire. The car would run only if you gave it gas, and it turned out being a clogged catalytic. We cut the cat out and it ranned perfect. Go figure...
Old Aug 5, 2007 | 12:28 PM
Zero4488's Avatar
Restricted User
My car throws a lean code and starts running rich and backfiring, I believe it's the O2's but I haven't gotten a chance to replace them....good luck..
Old Aug 5, 2007 | 02:33 PM
TX RED's Avatar
i had the same problem it was # 8 spark boot came loose and i was trowing maf codes
