Need Help this morning (window switch)!
On they dyno tune stage 2 switch there is 6 wires
Orange: not using because i'm not running stage 2
Green: Goes to tach wire #35 on pcm
Yellow: goes to #85 on relay
Blak : Ground
* White says to keyed 12 volt source or arming switch: Is this white wire supposed to be straight to a positive power source? Does it say arming switch in case you wanted to be able to turn it on/off?
* Green is supposed to go to TPS or WOT input wire...I can't seem to find any info as to where this goes???
the tps wire on a 98 should be the dark blue wire coming out of pin 12 on the pcm
in your first post you said your going through the pcm, why did you change to TB?
i couldn't tell ya because i went through the pcm
