Just a few Nitrous questions
Old Aug 5, 2007 | 08:04 PM
BigKap94z's Avatar
Default Just a few Nitrous questions
I just purchased a HSW single nozzle wet kit, Bottle heater, FPSS, Blow down tube, Dynotune purge, TPS switch/window switch, TR6 plugs and I think most of the other stuff to setup the Nitrous setup. I have been trying to search but have been having issues, what is everyone using to pull timing? I have seen the "timing tuner", is that the only option? I am looking to spray around a 150 shot, once some dyno time is available to check A/F ratio and everything. Would I still need to pull timing if I ran race gas? Right now I am cam/bolt ons making 421rwhp, I understand that I will need to upgrade to the Racetronix fuel system and thats not a problem. This will be used only at the track so I could run C16 or whatever fuel would be needed, if I can avoid pulling timing. All help would be greatly appreciated, and thanks in advance. Also if I missing any vital parts to my system let me know!
Old Aug 6, 2007 | 02:10 AM
SSDriver's Avatar
I have a timing tuner and love it. Although most will tell you its not needed with a 150 shot or smaller. Personally I'd rather pull the timing and be safe. When using nitrous you don't loose horsepower pulling a few degree's of timing. I run race gas with my nitrous but then again I have a stand alone fuel system so its not like I use a lot.
Old Aug 6, 2007 | 06:57 PM
BigKap94z's Avatar
OK, well are there any other timing retards that work with the LS1 besides the timing tuner? Any thoughts on whether or not if running race gas like C16 if I would "need" to still pull timing?
Old Aug 7, 2007 | 09:58 AM
Matt@HSW's Avatar
Our Interface controller will pull timing. There is a post in this section with a little info on the controller. It's still a few weeks away from being released.
Thanks,
Matt
