Fuel Pressure gauge
Fuel Pressure gauge
I'm getting rid of my useless air to fuel ratio gauge and picking up a fuel pressure gauge but have a couple questions.
I wasn't looking to spend a lot of money so I may have to go with a mechanical fuel pressure gauge. Is this even possible to have in a gauge pod in the interior of my car? I don't think I want a braided hose filled with fuel inside my car. Do people do this? Or do they only go with electrical for gauge pods?
How is a mechanical one installed? How about an electrical one?
I see that are 0 - 15 psi, 0 - 100 psi, and on a meter from 0 - 1.0. Which one do I need?
Thanks for the help.
I would not reccomend putting a mechanical fuel guage in the interior since if there is a leak there will be fuel spraying inside the car.
Mechanical and electrical are installed basically the same way. Mechanical the fuel goes through a fitting into the guage for a reading, and electrical the fuel goes into/through a similar fitting with a pressure transducer that provides an electrical signal to the guage.
I'm not sure what the 0-1 guage is for but the 0-15 is typically for carbuerated engines and a 0-100 for efi.
If you are spraying the car I would reccomend keeping the A/F guage so you can see if the car starts to run lean under the spray.
I knew how the actual gauge works but I meant, how are they installed? I assume they are just tapped into one of the fuel rails?
Originally Posted by ICRAZY6
Yes, taps right in the front where the shrader valve is. Or T'd off the fuel line going to the Fuel noid.
